Mack Truck plow frame
  • Mack Truck plow frame
    These are a few pics of a pusher frame i fabbed in my shop last week for a customer.All mig welded with my 250X .035 70S6 wire.Side frame plates are 5/8"thk.,pusher beam is 8"x6"x.375HSS. Uprights are 4"x4"x.25HSS.Truck will push a 11' plow.The top lift triangle is not installed the customer was still painting it along with the air/lift piston.
    Nice. How far back do the side frame plates go. Are you going to make supports behind the lower part of the pusher and make "arms" back to the frame. I want to do this to my old mans International Dump and put a 12 footer on it.
      Frame mounts
      The side plates are about 14"-16" long on the frame.They are welded to the underside of 6"x6"x1/2"thk clips mounted to frame with 7/8" Grade 8 bolts fine thread with nylock nuts.Also the 6x6 angle is trimmed to mount to the frame where needed.
        Does the hood still open? It looks like the mount interferes.
          Hood opens just fine.The front grill is stationary.
            Ok. Gotcha. Thanks for the clarification. I see it now. I'm used to the ones that have the grill attached.
