Cast iron/cast steel
  • Cast iron/cast steel
    Is there an easy way to determine if I have a piece of cast steel or if it is cast iron?
    Maybe spark testing...
    http://www.globalsecurity.org/milita.../14250_ch1.pdf
      If it will cut with a torch it is cast steel, cast iron will only melt
        Usually cast iron has a rough finish to it such as a cast iron frying pan or weights in a gym, engine blocks, looking close enough, you can see or feel the pores from the sand casting.
        Cast steel has a smooth finish to it like some cookware, motor housings, gears, sprockets, etc.
          Spark test.
            what is a spark test?
              Cast Iron will make a thud type sound if you hit it with a hammer wheras cast steel will haver more of a ring sound to it.
                Mig weld a piece of scrap steel to it.
                If it holds - cast steel
                If it falls off - cast iron
                LOL
                  Toe test! drop it on your toe, cast steel makes you say OOUUChh !,cast iron makes you say@#%%#^%#
                  Seriously though, spark test. Dull orange sparks off a grinding wheel are iron, steel is yellow.
