Gambles, any sugestions???
  • Gambles, any sugestions???
    I am looking at building a set of gambles for hanging deer. Any sugestions? thanks
    Don't make it too wide. I made this mistake once and had a dead hog laying on the ground while I was in the shop cutting and welding
    I use 1/2 rod and 1" black pipe (mostly because that's what I had laying around). Cut your rod to length for the end hooks. Hold them against the bench grinder and spin the rod to put a point on the end, THEN bend them in a hook shape. It's much easier to put the point on it when the rod is still straight. For the hanger in the middle I just U-bend another piece of 1/2 rod. Make sure this it big enough for a chain hook to pass through. Alternatively you could use a piece of 1/4 place with a hole and slot that will grab a chain between the links.
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
      I hope they had their day in court. What did they do. Steal some corn?
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        I would second what is said here, but would suggest you make one gambrel for deer (16"-18" wide) and a separate gambrel (12"-14" wide) for hogs. You will find this much more useful.
        Bill
        Miller Bobcat 225
          do you have something against shooting deer?
            thanks guys it was greatly appreciated, helped me out alot
              Actually I do.
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
                Actually I do.
                well some of us really enjoy it so if you dont like it keep it to yourself please, thanks, were not doing anything wrong by doing it so
                  Here is a link to an adjustable Gambrel. It seems pretty easy to clone.
                  http://www.texashunterproducts.com/ortgaga.html
