proper argon flow
  • proper argon flow
    i read in my miller dialarc hf manual that a flow of 15 cf per hour was sufficient but other welders tell me that 25 cf per minute is what they use.
    this is a huge difference in cost to me. any help out there?
    ty
    fuzzy
    15-35 cfh is typical. The actual setting depends on size of cup/tungsten, type of diffuser and whatever just works the best. Not much help, I know.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
      More flow is not always better. Start with your lowest setting and check the weld. No drafts around or doors opening either..that will blow / move the gas around.
        proper argon flow
        hey fuzzy,
        just checking your post and what i tell the guys at work is if you have your gas flow turned anything above 20-25 your just blowing your gas away from were it needs to be and that is the weld area, if you think about it i know some guys that have it cranked right up to 50-60 and all that is doing is blowing your gas all over the place and not at the weld were it needs to be it is crazy to have to turned up that high i think. but some guys really don't know the importance of gas flow and think if you turn it up the better it is.
        I hope this helps you,
        Syncrowave 250/Coolmate-3-(home)
        RMS-14 (kisser button)-(home)
        Craftmans/S-K tools-(home)
        Grizzly 16" vert band saw-(home)
        DeWalt chop saw-(home)
        Craftsman 4"-7" hand grinders
        Lincoln 225 arc welder
        Lots of vise clamps(not enough)
        assortment bar clamps
          Am I reading this right?
          ty
          fuzzy
          25 cf per minute is 100 times the flow rate of 15 cf per hour. Big difference. I am sure they meant cfh. The rule I go by is 14ga and under = 20 cfh. Over 14ga = 25.
          Hope this helps.
          Triggerman
          Ammonia refrigeration tech
          Trailblazer 302 (yes, it's new)
          Millermatic 180 w/Autoset
          CST-250
          HF-15 High frequency
          XR15 w/Push-Pull Gun
          Victor O/A, DeWalt, North mask
          "A professional knows what to do. A craftsman knows why."
            Originally posted by triggerman View Post
            .....The rule I go by is 14ga and under = 20 cfh. Over 14ga = 25.....
            Unless you (as I do) use a gas lens, in which case you can get by with even less Ar. On light gauge mild steel I use 11 cfh. and my welds look clean.
            Miller XMT-350 CC/CV
            Miller S-22A wirefeeder
            Bernard 400A "Q" gun
            Miller 30-A Spoolmatic w/WC-24
            CK 210 & WP-18 GTAW torches
            Hypertherm Powermax 30
            O/A Rig, Enco 4x6 bandsaw, etc.
              I almost always use 20cfh of argon, there's so many variables- cost, work area (drafts), material, gas lens.
              Miller Syncrowave 250
              6000+ hrs Al TIG
                It also depends on who is buying the argon.
                Tim Beeker,
                T-N-J Industries
                (my side bussiness)
                Esab 450i with wire feeder
                HH135 mig
                Miller aircrafter 330 - sold
                Marathon 315mm coldsaw
                table saw
                Dewalt cut off saw
                Sand blast cabinet
                lots of hand grinders
                Harris torch
                beer fridge
                  In my opinion anywhere from 15-35 cfh is good. It depends on drafts more or less. If your in a small shop with little draft, no doors opening all the time etc, 15 would be fine. You dont want too much gas flowing as it could cause turbulance and does not provide a good shield around your puddle. Depending on who's paying for the gas is also crutial.... lol
                  I would go with 20-25 cfh, it's a safe flow rate.
                  I weld...
                  Therefore...
                  I am....
