My DIY press brake 1
  • Joe from N.Y.
    started a topic My DIY press brake 1
    Here is my cheap solution for my need to find a way to bend some ” aluminum diamond plate for some brackets I needed to make. I made it after seeing some examples of DIY press brakes online. All welding was done with my MM211 with .035 wire. The die I made from an old piece of ” thick railroad scrap I found at the local Rail Road crossing.
    The 3/16” x 1 ” and 3/16” x 2” angle iron and ” round bar I had left over from other projects. The ” steel base plate I cut from the edge of a larger piece I was using as a welding table top. The round pipe was scrap left over after relocating some steam radiators in my house.
    I cut the railroad scrap down to about 12’ x 2” with a cheapo 4 ” Harbor Freight/Northern grinder with a good quality cut-off disk. I started out by using my plasma cutter on it, but found that the low-tech method of using the grinder and cut-off wheel worked better, leaving a beautiful clean edge.
  • strube1369
    Originally posted by Joe from N.Y. View Post
    Yeah, i forgot i got it from Northern. This is it: http://www.northerntool.com/shop/too...2331_200422331
    But i later saw this one on the HF site, and i would have gotten it if i had seen it before.
    Thanks Joe! We have a HF store here in Lincoln, Ne. and I love to go there...
  • Joe from N.Y.
    Originally posted by Bob the Welder View Post
    By Joe from N.Y. The handle on your grinder.
    OK, i get it. No, i was just grinding from different positions and getting some work done under the Jeep while waiting for crap to cool down. I kept moving the handle around.
  • Joe from N.Y.
    Originally posted by strube1369 View Post
    I really like that. Giving all that stuff a new life in a useful way. Nice job.
    Hey, what is the actual name of that HF grinder chop saw? Couldn't find it on HF website. Probably cuz I don't know what it is called...
  • strube1369
  • aametalmaster
    The handle on your grinder is on the right side. My buddy at work was a lefty and i am righty and we always had to swap the handles. Do you use the grinder in your chop saw?...Bob
  • Bob the Welder
    By Joe from N.Y.
    No, why, does something look backwards?
  • Joe from N.Y.
    Originally posted by aametalmaster View Post
    Nice job there Joe. Are you left handed?...Bob
  • aametalmaster
  • Joe from N.Y.
    (This is the last of the multi-part post.)
  • Joe from N.Y.
    The top gets slid onto the posts, and that’s it. I welded it along the edge of a larger piece of 1/4" plate i am using for my welding table, and just cut the edge of the plate off the table when I was done. (The table fits better in my garage now). I will add suitable springs under the pipe on each side when I can scrounge some up somewhere. In the mean time, it works for me. It bends 3/8” flat stock like butter
  • Joe from N.Y.
    Then I cut some more ” rod for the pipe on each side of the die to ride on, and welded them in place on the ” base. I used a cheap Northern grinder attachment that turns it into a mini chop saw.
  • Joe from N.Y.
    Then I cut and welded a piece of 2” angle iron to be the cradle of the brake.
    After aligning the top die to the bottom of the angle iron forming the base, I cut two pieces of the pipe and welded one to each side of the die.
  • Joe from N.Y.
  • Joe from N.Y.
    I then used the plasma at an angle to get a rough point along the edge, and then finish ground the point with another cheapo grinder with a grinding wheel. (They are so cheap, I keep four, each with different disks and brushes on them for different needs. It is easier than swapping the disks.)
    I cut two pieces of the 1 ” angle iron to the same length, and welded them, butted up against each other to form a c-channel, almost to the edge of my ” steel plate. Then I cut the ” bar to two pieces of the same length. These got welded into the angle iron to act as structural support to go underneath the bottom die.
