Making oil breather puke tank and tool modification
  • Making oil breather puke tank and tool modification
    Don't ya just love it when a plan falls apart. Man, crazy s&&t. Anyway, I have been asked to make a puke/oil breather tank like mine on my Nordic Jet Boat. The weird thing is this person has the same make boat.
    Ok, nuff, BS. Found some nice 6061 tube and made a drawing from mine on my boat. While I was fishmouthing the breather upright tubes on my Bridgeport milling machine the hole saw adapter broke when a tooth caught. Great, now I pull out the tube notcher I never used because I just use the mill for fishmouthing. ****, the threads are different on the shaft for my cheapie hole saws. I know, I will adapt the broken part to the shaft. My lathe does not have threading capabilities otherwise I would have threaded the tube notcher shaft. Sooooo, I made the hole saw adapter fit the tubenotcher shaft. It made it a little long but some angle and good to go.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    More Pics.
    HTP MIG 240
    HTP 380 Plasma
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
      Ok more pics. I don't use -10AN specific weld in bungs because they do not have a deep enough reach on the backside, because that is where I weld these on, the back. I turn down the NPT side and soak them in oven cleaner to remove the blue anodizing.
      Also notice the angle welded on the inside of the end plates. They are my baffles. I have them oriented vertically so when the oil hits the angle it drops out of the flow and into the bottom of the tank. I have to also weld a drain in this one. As you can also see, it is all about Jigging this right to get a good weld.
      T.J.
      HTP MIG 240
      HTP 380 Plasma
      South Bend Lathe
      Etc. Etc....
      tjsperformance.com
        More
        HTP MIG 240
        HTP 380 Plasma
        South Bend Lathe
        Etc. Etc....
        tjsperformance.com
          More
          HTP MIG 240
          HTP 380 Plasma
          South Bend Lathe
          Etc. Etc....
          tjsperformance.com
            Nice job! I have a love / hate relationship with the jobs where 1 project turns into 3 to get it done. Looks like it didn't slow you down much though.
            Sometimes there's no second chances.
