Anyone make ther own welding lead reel?
  • Anyone make ther own welding lead reel?
    I am thinking about making a couple reels for my welding leads after seeing what one of the welders made. I would like to hear any suggestions and tips that you guys have to offer. Thanks in advance.
    Synchrowave 180 Tigrunner
    Millermatic 251
    Trailblazer 302
    Spectrum 375
    heres a set i made
    no bearings, and they aren't hot, so it was easy to make
    just plug in jumpers from machine to reels and you're ready
    dave
      Welding Reels
      My Dad made a set that held over 100' and could be turning and welding at the same time He made to copper plates that was a perfect mate and interlocked together used them for 15 years than sold the truck. Work really good can make a drawling if you want. You will need a Lathe to make this kind where the kind Dave has would be easyer to make. And I'm sure works well.
        I would love to see a drawing or picture.
        Hobart Mega Arc 5040DD (with built in air compressor)
        MM Passport Plus with Q-gun
        O/A
        sold MM 251
        There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
          Originally posted by RoughneckDave View Post
          heres a set i made
          dave
          You say there not hot but it looks like you have a lug on the inside with a connector on the outside. Is this isolated from the reel somehow? The diameter of the pipe looks small, does the cable wind up o/k?
          MM250
          RCCS-14
            welding reels
            check the pictures I have of my rig under the thread. Hobart/ Miller at the lake. and you can see my reels, they are made from Alum. horseshoes. get a lot of comments about them. they are not live. have four. two for welding leads one for extension cord. and the other one I use for 200 feet of 10/3 cable so as to plug in my mig and tig welders for 220 power off of my welder. diverdown
            sigpic2001 Dodge Ram welding truck. Hobart champion 10.000, miller Diversion 165. miller 180 autoset with spoolgun. SIP plasma cutter. Airless plastic welder.1996 28 foot bayliner for hauling dive and welding equipment
              Hey vern, I too would like to see a drawing of the set up you used. I am thinking of making a set for my shop and need some ideas to ponder on. Thanks!!!
              Bob
                Here's what I did for the syncro 250 set-up..
                Steve
                Bobcat 250EFI
                Millermatic 350P
                Hypertherm 1250
                A Bunch of tools
                And a forklift to move the heavy stuff with..
                Torchmate 2x2 CNC Plasma
                It's Miller Time - Get Back To Work!
                  I built some about 10yrs ago. One is hot, they hold 300 feet of lead. I will post pictures tomorrow if you are interested.
                    Here are the reels I made. They have brass bushings. Nothing fancy though.
                      I have a tutorial on my website which lays out the math for building the right sized reels for the amount and size of cable you want them to hold. There are also pictures on the website of my reels and reel tree mounted on my rig.
                      http://www.coalsmoke.com/Coalsmokes/...3A_part_1.html
                      Coalsmoke's Website
                        homemade reel
                        I am in the process of building a set as we speak. Any luck and they will be finished this weekend. I built mine from some old trailer hubs I had laying around. I will try and post Picts when finished
                          I have a quick question men. When installing the lead to the reel, are any of y'all putting dielectric grease between the copper terminal and the reel. Or is it just metal on metal?
                            No need for a reply. I now have them painted and finished. I just finished wiring them in. Hope this helps.
                              Add Content
