fixing a dent
  • stugots
    started a topic fixing a dent
    fixing a dent
    this job come in today,,, its a dent
    im going to fix it,
    first i use a stud gun (it welds the sticks onto the panel) and start pulling the dent out.
    next i take pictures and post them to the internet.
    later i will use a hammer and dolly,, and start bondo and paint,, but we are not there yet.
  • stugots
    color matched to perfection
    ill buff this out in the morning and collect my money!
  • welder_one
    looks pretty good so far...
  • stugots
    epoxy primer
  • stugots
    i always spray primer on bondo at the end of the day so water doesnt soak into it.
    i sanded that back off,, used a thin bondo to bondo the bondo and a powered guide coat,, again sanded off by hand.
    now its ready for the primer and ill blend the paints together on that panel, after that, i clear coat the entire panel.
  • uhohjim
    That scoop means the difference between a Lemans hood and a gto hood.......both of which are getting harder to find clean rust free examples of. I'm a big fan of saving stuff like that myself.........that's why I've got a pole building filled to the gills with crap I'll probably never use or need.......till right after iI get rid of it lol Jim
  • stugots
    when i did that 65 gto conv resto, i replaced the hood due to rust in the nose..
    i took my zip wheel and cut out the old 65 scoop section and sold it on ebay for 150.00 and trashed the rest of the hood.
    5-6 people wanted it too!
    just the scoop part with 2in of meat going around it.
    crazy, huh?
  • uhohjim
    Originally posted by SundownIII View Post
    Uho,
    Yeah. If you haven't figured it out, I was pulling his leg a bit.
    Nothing wrong with bondo if used properly. I first used it in the 60's with a Corvette I had. Little hard to use lead on fiberglas.
    Problem with bondo is that so many people use it wrong. Use it as a "crutch" to get around poor bodywork.
    This new hi-strength steel used today, I'm sure, would throw me a curve. I was taught how to use a torch and wet rag to shrink metal by my uncle more years ago than I care to think about. I'm sure it wouldn't work with todays materials.
    It still works ..Just a little more temperamental than the older stuff......I did some lead work recently on a 70 nova hood that I welded a cowl scoop on.........lemme tell yuh the hood took the heat no problem,the aftermarket scoop on the other hand wanted to walk all over.....had to refine my method a wee bit but it worked out ok.. Jim
  • stugots
    bumper bracket reinforcement technique
  • SundownIII
    Uho,
  • uhohjim
    Bondo.
    Real bodymen use lead.
    You're not using lead on that area of a new car........more warpage than you'll want to deal with....coming froma bodyman who uses lead.
  • stugots
  • stugots
    yea,, i dont even want to deal with a dealership in the correct way, as im not the owner and i have no title,,, im hoping someone here may work for honda and could pm the code,,, so i dont need to do all that...
    in the morning im going to call dealership parts counters and try to sweet talk the code from someone over the phone.
    but im no good at sweet talking due to my abrasive personality.
  • Blondie_486
    Originally posted by stugots View Post
    i tell you what i do need,,,,, the stupid radio code for this honda
    the radio number is U2420 L2537
    hope someone here can get me it! LOL crosses fingers
    To get the radio code you will have to take the radio and the title to a Honda dealer (parts dept) and they can either look it up or call Honda and get it. The reason for all of this BS is to prevent theft. I had an Accord I had to do just that with. The part that ticked me off is when I pulled in the lot I hadn't even got out of my truck yet and they wanted to sell me a new car, then as I was leaving a different salesman (liar) tried the very same thing.
  • Blondie_486
    Bondo.
    Haven't you heard? Lead is now considered both environmentally and politically incorrect.
    I guess I'll be incorrect!
