Projects Recently completed/In the works
  • Projects Recently completed/In the works
    Anybody have pictures of anything they have completed recently or something they are working on they would like to share (brag about)?
    Homemade 12"Disk 6x48 belt sander
    http://www.youtube.com/watch?v=_ZQykgSsI2s
    Tap on the above line
      Due to confidentiality nothing I can talk about or show. It was quite complex and took a little over 2 months to complete.
      Miller 340A/BP
      Victor O/A torches
      Lincoln SP125
      Too many other tools to list
      03 Ram 1500
      78 GS1000
      82 GL1100 Interstate
        I hear that. I've signed more than one non disclosure agreement myself. I'll start posting some of my own projects as soon as I get another digital camera.
        Sometimes there's no second chances.
          Not welding related...but
          I've almost got my 1970 Chevy 3/4 ton running around.
          http://c4.ac-images.myspacecdn.com/i...170e5249a7.jpg
          Picked up a 454 with TH 400,
          http://c4.ac-images.myspacecdn.com/i...952afa58ff.jpg
          Did a leak down...thought the motor was great. Checked the bearings...they were destroyed...Rebuild time! Found out it was bored .060, so it is a 468...a little more displacement never hurts :P
          Replaced the factory crank, with a cast steel Scat version, with new main and rod bearings. Plenty good for the power I'll make. New cam bearings, new Edelbrock cam, gasket matched heads and intake, new valvesprings, crane roller rockers, Melling high volume oil pump, new ARP rod bolts, Edelbrock performer rpm intake, new weiand water pump...and there is still more going into it.
          http://c2.ac-images.myspacecdn.com/i...82f7f0e885.jpg
          http://c1.ac-images.myspacecdn.com/i...b4e5c27b88.jpg
          http://c2.ac-images.myspacecdn.com/i...e2176b4735.jpg
          Just need a new flexplate, starter, and carburetor. Motor should be complete, and bolted back to the trans by the end of the weekend, except those 3 parts.
          I guess I have one of the trans, when it was still apart. TransGO shift kit. Mildly boosted line pressure, control of manual low at any speed...and some other cool stuff.
          http://c2.ac-images.myspacecdn.com/i...f7ef658131.jpg
          And because I've posted a few things about this truck...but never pictures, here are a few more.
          http://c1.ac-images.myspacecdn.com/i...2913cc2eb8.jpg
          http://c3.ac-images.myspacecdn.com/i...bea355be7e.jpg
          That trailer is 17.5' That might help put the rest of the truck in perspective.
          That's my current project though!
          Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
            Nice! One of the best styles of truck ever made IMO.
              Swivel shooting bench
              This is my first project with my new MM252 I purchased last fall. There was some welding, some machine work and some woodwork. Not completely done yet, still deciding on a final size and shape for the top and the length of the arm for the seat. Each leg can be individually adjusted for uneven ground and the whole thing swivels 360 degrees. I use it to shoot at (educate) groundhogs. I already posted this under a different thread. Also tried to put it into the projects pictures but it never showed up. I had my brother who outweighs me by nearly 100 lbs sit on it to test my welds. It will never move with me on it. Every place that moves with metal on metal has a bronze bushing in it. I tried to do as "professional" of a job as I could. After this past winter I'm thinking of building a cab for my compact tractor as my next project.
                Whack a mole with gunpowder and lead, L.O.L. That's a fine looking bench, sure beats laying on the ground.
                  We call them "Whistle Pig's" out here, and I have been known to educate a few myself. Good job on the bench!
                    Here are a few jobs i have been doing this week. The first one is the Plant Stands. I do lots of them esp this time of year.
                    Speaking of this time of year its The Steel Valley Super Nationals right now in my town and driveshaft work is doing well. Just finished my 123rd and 3rd this week. Seems like everyone forgets they need a shaft cut down for their ride...Bob
                    http://www.steelvalleysupernationals.com/
                    Bob Wright
                      Looking at the graphic at the top of the Steel Valley Supernats page I see our "Rat Fink" of yesterday has been replaced by some alien looking creature!!
                      Miller 340A/BP
                      Victor O/A torches
                      Lincoln SP125
                      03 Ram 1500
                      78 GS1000
                        Yes it does. Kinda makes you feel good when you see 300 cars sitting in a lot and you can pick out all the parts you made and welding you did on some of the cars over the last 30 years. Just finished up a driveshaft for a '65 Ford F-100 with a 429 and dual turbos. I saw the kid cruising town about an hour after it left my shop...Bob
                        Bob Wright
                          Just some stuff i've done recently. I am now known as the "dude to call" for welding jazz that needs to be done at the shop where my dad works!
                          The pull up bar is for my brother, shelves are for my other brother's tool room where he works, and the cart is for my Red box!
                            Not a lot of "welding" in these, but they are cool and made of metal!
                              Yeah there is a kind of feeling seeing something you built or built parts for rolling down the road, dragstrip or at the local cruise in. Speaking of cruise in's do they still have them anymore. I remember the Apples/Arby's parking lot in North Canton had a weekly cruise in, and we used to have one at the old drive in burger joint in Ravenna till 05. Seems like "bike night" is the "in" thing now and I do enjoy those as well but never have any time to go anymore nor a riding partner.
                              Anyway keep up with the drive shafts there aren't many guys who do them anymore. If I had the equipment I'd do them but no way to balance them. By the way how's retirement treating you??
                              Miller 340A/BP
                              Victor O/A torches
                              Lincoln SP125
                              03 Ram 1500
                              78 GS1000
