Bed Project
  • Bed Project
    I finally got a few days off from the rig and got some real work done on a custom bed project for a bedroom renovation. I liked the modern look of zebrawood and wanted to incorporate some metal in my design too. But zebrawood from the local hardwood lumberyard is about $30/ft. So I made my own out of plywood. The inserts for the headboard and footboard are made from stainless and copper woven together and sprayed with some clear to keep from tarnishing. Pretty pumped about it. Just have to make the side rails...when I get some more time.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Bosch 12" Double Bevel Miter Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    and this heavy duty table I made
    sigpic
    Thats pretty slick and creative.In the photo the stain appears really dark is that the effect your after or did you have a problem with the end grain of the ply getting too dark and needed to stain the rest to match?Mike
      It's stained two ways because I like to make things incredibly difficult for myself. I put an ebony paint stain on first. It seeps deep into the soft sections of the plywood for kind of a flat finish and then is glossy on the end grain of the ply. I sanded the legs down so that only the soft remained black and then put a walnut stain on to darken up the grain.
      MillerMatic 252
      Spoolmate 200
      Diversion 165
      Delta Drill Press
      Bosch 10" Table Saw
      Radnor O/A
      sigpic
        Nice Bed
        Nice job. I like the zebra effect with light and dark wood. It looks like a sturdy mutha. This is my next project - except out of steel. 1 1/2 X 4 rectangular tubing with stretched metal for a top.
          Dang it. Now I want something like that. Oh well, there's more than just one room in my house. And a reason to buy a roller.
          MillerMatic 252
          Spoolmate 200
          Diversion 165
          Delta Drill Press
          Bosch 10" Table Saw
          Radnor O/A
          sigpic
            And it will be easy to move when you rearrange the room Mike
              Looks like that will require some thoughtful sleep.
              NoogaD:
              Looks like a nice project.
              Miller Syncrowave 200
              Homemade Water Cooler
              130XP MIG
              Spectrum 375
              60 year old Logan Lathe
              Select Machine and Tool Mill
                looks really nice - what gauge metal do you use for the weaving?
                  I used 16 gauge stainless and 16 oz copper. Figured anything less would be too easy to bend and burn through. It's very sturdy though.
                  Thanks Nocheep!
                  MillerMatic 252
                  Spoolmate 200
                  Diversion 165
                  Delta Drill Press
                  Bosch 10" Table Saw
                  Radnor O/A
                  sigpic
                    nice bed
                    I like the lattice - but... how did you get all the edges smoothed out - just a whole lot of filing and emery cloth?
                      I used an abrasive disc on my grinder to get the mill scale off the stainless and rough up the copper. It cleaned off the burrs from the edges as well. The clear spray paint also takes a little bit of the edge off. I didn't need a high polish; plus, you would scratch the polish badly trying to weave the strips and getting those cleaned up after weaving is really difficult. I ground down the tack welds so the inserts would fit in the rabbits of the wood.
                      Also, I found that the 4 1/2" abrasive discs from Harbor Freight for about $5 last a good bit longer and don't heat up and leave residue quite as bad as the 4 1/2" Gator Grip discs from Lowe's that cost about $11.
                      MillerMatic 252
                      Spoolmate 200
                      Diversion 165
                      Delta Drill Press
                      Bosch 10" Table Saw
                      Radnor O/A
                      sigpic
