DIY Step Stool Plans?
  • DIY Step Stool Plans?
    I'm needing some aluminum welding practice, and I thought that making
    a step stool would be a "nice to have around the shop" project.
    Yeah, I know that I could just buy one.... but i've got many pieces of
    3/8" thick plate, and at least one TIG welder around here.
    Does anyone have an example of one, which they made, that they'd be
    willing to share?
    _kevin
    Syncrowave 250 Analogue
    Maxstar 200SD
    Maxtron 450
    IntelliTIG 40
    S64M Wirefeeder
    Non-Blue:
    Hypertherm PowerMax 1000G3
    Lincoln Precision Tig 275
    Lincoln WeldPak 155
    I'm making a set of stairs out of 1.25" aluminum radiused corner square tube. I'll post some pics when I get it started.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
      I always try to avoid stepping on any stools!
      Miller Syncrowave 200
      Homemade Water Cooler
      130XP MIG
      Spectrum 375
      60 year old Logan Lathe
      Select Machine and Tool Mill
        I don't mind being waist deep, i just don't like it when they make me stand on my head!
        Sometimes there's no second chances.
          Flip a milk crate upside down then copy it.
          MM250
          RCCS-14
            step stool
            Make the base larger than the top for safety, won't tip when you reach too far
              How about making a box that's 1x1.5x2 ? Maybe cut hand hold ovals in the center of the sides.
              Stand it on whatever side for the required height.
              We had a few boxes made like this out of plywood in a shop I used to work at.
              Do you think Aluminum would slip on the grit on the floor?
                You could do a Google search for "step stool plans". You will find many wooden step stools of all kinds to build. All you will have to do is translate the plans into thinner aluminum stock. The proportions and part shapes will remain the same.
                Here's a link to a simple one /www.woodworkingcorner.com/stool.php
                Charley
                ______________________________
                Miller MM252
                Miller Bobcat 225NT
                Miller DialArc HF & DIY Cooler
                2 Miller Digital Elite and 3 Fixed Shade Helmets
                2 O/A torch sets
                DeWalt 18 volt 1/2" Driver/Drill
                DeWalt 18 volt 6 1/2" Metal Saw
                DeWalt Porta Band & SWAG Offroad V3 Table
                Milwaukee 8" Dry Cut Saw
                Milwaukee 14" Dry Cut Chop Saw / Delta Stand
                Milwaukee 9" Grinder
                2 Milwaukee 4 1/2" Grinders
                Milwaukee Hole Hawg 1/2" Drill
                Wallace 5 Ton Gantry
                Too many hand tools
