Pulse Mig Gas Question
  • Pulse Mig Gas Question
    I just bought a MM350P with the xr alum pro gun last week. I have been running regular MIG mode due to the fact of not having time to play with the pulse. Well Saturday came and I had time. I got the pulse running nice. I used the book settings and dialed in the arc length and sharp arc settings.The book alse recomends a 90%argon/10Co2. I used my 75%argon/25%co2 tank with good results. I was thinking about getting a 90/10 tank on my next refill. Will there be any difference? I am welding steel by the way. I think I will be pulse mig welding everything now. It's really nice! What is the difference if any in the weld appearance or structual qualities with the 90/10?
    At 1st I was not impressed with anything except the guns smooth wire delivery over 25ft. It was'nt untill I got the pulsed mig going that I was amazed. I can't wait until I can run alum.
    Mike
    MD Welding & Fabricating L.L.C.
    mdwelding@sbcglobal.net
    At 1st I was not impressed with anything except the guns smooth wire delivery over 25ft. It wasn't until I got the pulsed mig going that I was amazed. I can't wait until I can run alum.
    Praxair's Mig Mix Gold (90-10) works well on pulse. I use Praxair's Stargon, 90%Argon, 8%CO2 and 2%Oxygen. I'm not a real weldor, and can't tell if there's a difference.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
      MD Welding,
      Nice setup you've got there. Glad to hear the pulse is working out for you.
      Be careful, several posters (one of which I think was with Miller) have noted that the Push/Pull gun was designed for aluminum and a constant diet of steel wire will prematurely wear out the liner and that the liner for that setup is "VERY" expensive.
      Don't have a push/pull myself but thought I'd throw that caution out there. Might be worth a call to Miller tech support.
      Syncrowave 250 DX Tigrunner
      Dynasty 200 DX
      Miller MM 251 w/Q300 & 30A SG
      Hobart HH187
      Dialarc 250 AC/DC
      Hypertherm PM 600 & 1250
      Wilton 7"x12" bandsaw
      More grinders than hands
