how high a welding table should be?
  • nachche
    started a topic how high a welding table should be?
    I'm planing my first table.
    i thought about 90 CM from the floor. so I can stand and work comfortably.
  • Pass-N-Gas
    Originally posted by Vernon View Post
    How do you like these chains
    What only single row?
    I just finished up a gear box for a pumping unit, would you like some triple row 120
  • Broccoli1
    Some times people should not open up Sketch-Up
    http://www.millerwelds.com/interests...welding-table/
    It is a welding table- don't think about it too much
  • Vernon
    Chained Bottles
    Originally posted by Pass-N-Gas View Post
    Vernon I'm impressed a chained gas bottle on our site
    Keep the saw off the table you don't want to un-clamp a project to cut the next piece for the same project..
    My top is 39" with some adjust-ability to it.. it is the same height as the work bench..
    If you look at the metal rack on the wall you will notice the removable rollers, they match up to all of my shop equipment stands Chop saws, miter saws, planers ect
  • Pass-N-Gas
    The height of my bench is 35" or 88.9 cm The bench is 48" x 96" (121.92 x 243.84 cm) this works well for me at 6'4" (193.04 cm).I like it very much. Hope you find what works for you. I add a picture of my bench for you.
  • nachche
    new table design
    ok
    you got me on that cm...
    after thinking about it (and taking your advises)
    I redesined my table
    here are some pictures of it: (the height is 86cm (33.8")
    what do you think about the wheels?
  • Bob Miller
    40 3/4"
    My table is a piece 3/4"(19mm) plate 36"(91cm) in dia. I put 3-40"(101.6cm) legs on it.
    It's fine for little things, but any thing very tall I have to stand on a box.
    For tig welding I can sit on a bar stool and work the pedal.
    Mig welding it's fine. Stick welding, it's back on the box again.
    Before I would cut that one down, I'd build one a litte shorter, maybe 4"or 5"
    (10cm or 12.7cm) shorter.
    Bob
  • Vernon
    Steel Bench
  • tenfingers
    I built my table 42" high. it's very comfortable standing / working if the projects aren't too big. However it puts the vise way to high. I'm thinking about receiver tubes on the legs to bring the vise lower.
  • Scott Hightower
    Table Height
    Of course it depends on the height of the work and the height of the operator.
    All of the tables in my plant are adjustable from about 28" to 38". Some legs are a tube inside a tube with a quick pin. Others have back to back channels with slots.
    Scott
    Fab Manager
    Welders360
  • FusionKing
    Originally posted by nachche View Post
    thank you all for the replys
    I am considering again puting the saw on the table..
    i found out that 85 cm will be good for me (I'm 1.83 cm tall)
    do you have some pictures of table legs that can be shorten ?
    WHOA!!! Are typing this on a standard size keyboard??
  • Broccoli1
    You'll need a ladder to reach the table
  • nachche
  • Rascal
    I am 5' 10" tall. All my benches are 40 inches tall. This seems to be the perfect height for me and those I have made benches for in the past. You obviously can make the bench any height you wish. If you are going to stand at the bench like you said you are I am sure you will find that 90 cm is too low for most tasks and will be hard on your back. I also suggest you add some receivers as others have mentioned. Good luck.
  • Rick C
    here is my table it is 35 inches tall it fits me I 'm 5'8".
