finished my table
  • finished my table
    Gave someone my design and they drew it out and laser cut the top out of 3/8", its 30" x 60". The x pattern spec was from a member here, and I bought the Miller Xclamp to use. There is a bunch of 9/16 holes as well, can't see all of them due to the crappy cell phone pic. Height is around 34". Made a tray for random junk, stainles tubing on the sides for hanging things, and adjustable feet due to my unlevel shop. Add a $3.99 can of canadian tire rust paint (okay, it was a can and a half) and done like dinner. Came out pretty good I think. Can't wait to use the TIG on this as opposed to my wooden folding table with a piece of warped 1/4" plate resting on top.
    Matt
    Nice table. I'm assuming the hole cut at the end of each slot means you can lift the clamp out and move it?
      Yep you bet, the clamp just goes in the hole and then you slide er up and down. and I just realized those vice grips on the right look like they are on the ground, they are actually on the right 'tray' that is expanded metal grate or whatever its called.
        Nice table. How much did it cost to get the top cut if you don't mind me asking? I realize that it'll probably be twice as much here in SoCal (unless you're in SoCal too), but I was just curious, because that's a really nice feature. I was thinking of doing slots as well.
          Nice looking table, almost might make a guy not want to use it.
          Great work.
          Tom
            Great looking table!!! I like the slots for clamping too great idea!
            Jack I just spent about an hour looking at your garage that's cool dude!!
            Tim
              Tim
              Jack,
              Nice write up on the garage. Your garage makes mine look like a garbage dump.
              Charles
                Thanks, guys. It's not usually all cleaned up like you see in the photos, but I try and get it back to the starting point in between projects.
                Gratuitous picture:
                Now, if I could only find room for a welding table with clamp channels in it, like crawler.
                  sorry but what are the X cutouts in the table top for?
                    Miller Xclamp.
                      Nice!!!
                      Cant wait till you show us your back yard vineyard and winery.
                      Just kidding. But.... I seriously envy people that are as organized as you.
                      My head down, **** bent on productivity mind set, has always gotten in the way of my organizational skills.
                      Cheers to your garage!
                      Gratuitous picture:
                        Nice table ! Where can I get the X pattern that you used - I am thinking I can pester my buddy to cut me one of these tops as I think he has a laser at his work.
                        Thanks,
                        Lewis
                          Jack Olsen, that is one fine looking table! I really like the arch in the lower support. Is that a solid piece that you bent by heating, or a bunch of smaller pieces welded to form the arch? I believe a table like that would be equally at home in the house or the shop.
                            Originally posted by fendermender View Post
                            Nice!!!
                            Thanks. It's funny, my home office for my day job is a mess, pretty much all the time. But my garage stays clean, in spite of the fact that I do a lot of work in it.
                            Thanks. It's a piece of 2" square tubing with 16ga walls. The rest of the table is thicker steel, but I knew I'd need one piece to bend. I tried bending it with a cheap roll bender, but I didn't get very far because I only had round dies. So I made a series of cuts and then cleaned it up with some body filler.
                            Sorry for the thread hijack. I'm still trying to think of how I could cut X's in my fold-down welding bench.
                              Matt
                              Matt, great looking table. I want to make one also. What are the 9/16" holes for?
                              John
