sharping tungen
  • sharping tungen
    I have a tig and I do not know how to use it but first thing is to sharpen the tungen. That is on mild steel, so now I would like to know if it is better to sharpen it on a grinder or on a belt sander. I am not doing a lot so I did not see the sense in buying a tungen sharper. I am just playing around with the tig. So all the help that I can get is good.
    JJE:
    Rather than post an answer to this, let me suggest that you go up to the top bar, search, and type tungsten sharpening in the box. You will find a large number of threads with a wealth of information to wade through.
      well
      well my buddy at work sharpens his on a wheel grinder, and hes been doing it that way for about 6 years so however you want to do it i guess
        I have been using an angle grinder to sharpen tungsten for over 35 years and I use the same wheel if I am welding stainless, carbon steel or anything else without any cross contamination.
        Hope this helps
        Wheelchair
          Thoriated electrodes - warning
          In the event you are working with Thoriated electrodes (red band of color on the end), be aware they are mildly radioactive. Many welders like them because they work great. You could probably lick them all day long with your tounge and not suffer ill effects, but grind it into a fine dust (when you are sharpening it) and breathe it and you are asking for lung cancer.
          A welding instructor from a local high school recently died before his time, of lung cancer.
          I've been told the dust is so heavy that it will settle-out and you will never breathe it while grinding. Then why is there grinding dust on my respirator when I take it off? For me, I do NOT buy Thoriated electrodes. Lanthinated works fine for me. Costs a little more, but how much is our health worth?
          Dynasty 200 DX
          Coolmate 3
            sharping tungsten
            thinks for the info. I just want to get all info that I can
              I sharpen mine on the belt sander, seems to work better then the grinder, more control.
              Tim Beeker,
              T-N-J Industries
              (my side bussiness)
              Esab 450i with wire feeder
              HH135 mig
              Miller aircrafter 330 - sold
              Marathon 315mm coldsaw
              table saw
              Dewalt cut off saw
              Sand blast cabinet
              lots of hand grinders
              Harris torch
              beer fridge
                I've switched to all Lanth except in .040 (can't find it). I grind with a diamond shaping wheel off E-bay, ($45). Look under "lapidary materials" I think. I love it. It produces a good clean tip and a great arc.
                Webb's Welding and Repair LLC
                MM210 w/a 3035 spoolgun
                Spectrum 625
                Trialbazer 302 w/HF
                http://webbsweldingandrepair.com/home
                  I have used a belt sander and a grinding wheel. Both work fine. I usually sharpen to 1 1/2 times the diameter or so.
                    Chuck it into a cordless drill and sharpen it on a belt sander. Works great!
                      sharping
                      I forgot to ask how sharp does it need to be. I am going to use the drill and belt sander.
                        sharpen it to a fine point 1 1/2 time the diameter
                        trail blazer 302
                        hypertherm plasma
                        millermatic 251
                        high feq. arc starter
                        suit case (extreme 12vs)
                        o/a torches
                          tungsten
                          how sharp dose it need to be for mild stell
                            Sharping tungen......Not a clue!
                            Nick
                            Miller 252 Mig
                            Miller Cricket XL
                            Millermatic 150 Mig
                            Miller Syncrowave 200 Tig
                            2-O/A outfits
                            Jet Lathe and Mill
                            Jet 7x12 horz/vert band saw
                            DeWalt Multi Cutter metal saw
                            Century 50 Amp Plasma Cutter
                            Propane Forge
                            60" X 60" router/plasma table
                              If I remember correctly from the little bit of tigging I was taught. Sharpen it to look like a ball point pen cartridge and for aluminum, it should look similiar to a Q tip.
                              Ken
                              Hobart Handler 187
                              Dewalt Chop Saw
                              4" Air Grinder
                              Die Grinder
                              Rigid Drill Press
                              Kellogg 10hp Air Compressor
                              2009 FXDC
