Enclosed concession trailer design ideas
  • Enclosed concession trailer design ideas
    I am considering whether to build a concession trailer out of steel. Here is a commercial example.
    http://www.supremeproducts.com/specs16.html
    I would make it a frame of steel members and the side panels and roof would also be steel.
    Are there any suggestions for a design?
    The probable size would be about 8' wide (probably 8' 4'') and about 16 feet long (exclusive of the tongue and hitch) and the box (exclusive of the suspension members) would be about 8' high.
    My thinking would be to build a frame for the side panels and roof and weld the plates onto the frame members. I am thinking to space the frame members somewhere between 2' and 4' apart. I am thinking of using either 14 gauge or 16 gauge steel for the plating. I am thinking I would have both outside panels and inside panels, both for the walls and the roof. I am thinking that the frame for the walls and the roof would be 2" square tubing of 14 gauge. What would be most appropriate? I would like it to be somewhat beefy, but I am a bit worried about it being too heavy.
    My rough calculations are telling me that the basic box is likely to be well over 3000 pounds.
    The base would be made of square tubing. Would 2" 14 gauge square tubing be sturdy enough?
    I am thinking that it would probably require tandem axles.
    Please give me any good ideas for design and construction that you have.
    Thanks.
    P.S. Suggestions such as "don't build your own trailer" are also valid.
    I have seen them for sale at prices that couldn't be beat, let alone the work. I wouldn't even consider building one. Spend your time shopping.
      I have . .
      I have owned several concession trailers . . .
      You have to ask yourself some basic questions first.
      What will you be doing in it? Baking, frying, grilling, etc . . .?
      Have you designed the interior layout?
      You may want to consider a removable tongue.
      I could go on, but lets get some basic info first . . .
      As for "cheap" concession trailers, those are just cargo trailers with a sink.
      Check these out . . . real "CARNIE" food joints . . .
      http://www.waymatic.com/default1.htm
      Millermatic 251
      Lincoln AC/DC "Tombstone"
      Milwaulkee Grinder 4 1/2"
      Clark Grinder 4 1/2"
        wacko them trailers are fricken awesome ive seen a many of shops with less class
          I think you would be ahead just to buy one all set up but thats just my thoughts
            I got a quote from one concession trailer maker in California for one that is all set up, and it came out to about $40k, which is more than I can afford to spend.
              My main product offering would be frozen custard (the real stuff, not soft serve). I already have the machine.
              I would also consider the possibility of including a griddle and/or fryer to allow for a secondary line of of product, but it may be better to keep it simple, in which case it would just be frozen custard.
              Using a CAD program I have been sketching out some trailer layout ideas off and on for the last few months, but haven't settled on a definitive layout yet.
                I found a project on this web site that is vaguely similar to what I had in mind.
                Here are a couple of links to the project.
                http://www.millerwelds.com/interests...ct/2423140061/
                http://www.millerwelds.com/resources...ead.php?t=2435
                However, mine would need to be bigger. I would also do welded plating (probably 14 gauge) for the outside and inside surfaces. (It looks like he screwed panels on rather than welding them.)
                I'm sure it would be a lot of work.
                I am attaching a sketch of the concept for the floorplan.
                  Just one request from a future customer, make the awnings 7' high minimum. Curbs are about 6". When you pull up on the curb with a 6.5' awning, anyone over 6' needs to duck to order etc.
                  From someone that used to work in kitchen - the ultimate goal is a floor that you can pretty much hose out when it gets too dirty.
                  Con Fuse!
                  Miller Dynasty 350
                  Millermatic 350P
                  -Spoolmatic 30A
                  Hypertherm PowerMax 1000G3
                    I would tend to think there are used ones floating around for a fraction of the price? Look on ebay?
                      http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_1479wt_941
                      I'm sure there are others out there- this is a buy it now
                      Ed Conley
                      MM252
                      MM211
                      Passport Plus w/Spool Gun
                      TA185
                      Miller 125c Plasma 120v
                      O/A set
                      SO 2020 Bender
                      You can call me Bacchus
                        Going to be hard to beat those deals, even material cost will be close to what you can hook on and go today for.
                          It's true that there are a lot of concession trailers listed on ebay. I have a standing search the alerts me each day for new listings of concession trailers. So far none have been quite right. Actually, one was pretty close to what I would want (good floor plan), and it was only a few miles away, but (long story) I didn't see it until the auction was closed. It's a pity because it sold at a rather low price too.
                          I also regularly look at Craigslist and other local classified ads. Sometimes concession trailers show up there, and I have looked at three so far, but they either weren't suitable or ended up being sold before I could make an offer.
                          One of the special requirements of my setup is that I have a very large and heavy condenser unit that will need to be roof-mounted. Another thing is that most used trailers would have to be at least partial gutted and rebuilt in order to get the floor plan right. All that remodeling will take a lot of work and cost some money as well.
                          Building would likely take even more work, but at least I could customize the floor plan to the best fit for my purpose.
                          Still, looking for a used one is an excellent idea, and I think it might be slightly less expensive to buy a used one than to build one myself from scratch, provided I could find the right unit to start with.
                            All the doors. latches, all that stuff is super time consuming to build, modifying starting with a basic unit would be so much faster, there just isn't room to save a lot in this deal.
                            I have built trailers over the years, only way I do it now is if its something special. They are so competitive its tuff to buy the materials for what you can buy one for.
                              Good ideas, both of them.
                              Following up on one of your comments, if the unit were made of painted steel would it be easy to clean by the hose method and some long handled brooms and brushes? It seems to me that this would get the big stuff, and the rest could be touched up by hand.
                              Regarding floor plan, if the dipping cabinet for the frozen custard were placed behind the person at the serving counter, how much space would be needed for convenient operation? Do you think that 2' 4" would be squeezed too tight?
