Smoker's Done!
  • Smoker's Done!
    Thought I'd start a new thread figuring the old one had gotten all the visits it was gonna get. Here's the build: http://www.millerwelds.com/resources...ad.php?t=20594
    But now it's 99.99% complete. The drawing for this beauty is going to be held 3/27/10. Now is the time to get your tickets! PM me.
    Thats one fine rig. Great job!
      as we say here in BAWSTON "wicked shahp!" we don't believe in "r's" all that much
        You do fine work nocheepgas!
        That is a fine looking rig you have built. Who ever wins it is going to be walking tall taking it home.
        Great work for a Great cause.
        Tom
          nice that looks like something that I need
            very nice looking trailer/smoker!
              looks good, I like the double stacks.
                sweet rig!!! how do ya get sm tickets??
                  I was wondering...
                  What is the finish used overall?
                  Does it require heating to set?
                  Have you heated it up yet and checked the temperature across the length?
                    that looks awesome!
                      Send me a PM
                        Originally posted by Kamikaze View Post
                        I was wondering...
                        The overall finish is a Dupont industrial coating. The fire box is sprayed with POR 15 silk, which has a temp rating of 1200 degrees. The POR 15 has only 1 coat and can be recoated after heating to 400 degrees.
                        Not going to fire it up, that's up to the winner. Couldn't raffle off a used product....
                          nocheepgas,
                          Thank you for the reply.
                          I understand about not firing it up and leaving it up the the winner.
                          I have been watching your progress with great interest since I am assisting a friend with re-building his smoker that did not function well.
                          I am curious if you have created other smokers in a similar fashion and how the temperatures were across the grilles from the firebox to the stack area. This is one of the problems we are addressing with my friends unit since he had such a severe temperature drop from one end to the other.
                          Also, even though you lined the firebox with firebricks, I was concerned with the fact that you have an open face grille above and how that would affect the ability of the heat and smoke transfer into the actual smoker itself. I see this as a point where the needed heat escapes upwards instead of into the actual smoker.
                          Please don't misunderstand my questions, as I am not cutting up on your design or build. IT IS EXCELLENT!!!
                          I'm just trying to understand how you have built and overcome the problems that we see are happening with a similar (albet, Backyard), construction that is not working for us.
                          Any of your expertise and knowledge you are willing to share would be appreciated!
                          Again! AWESOME BUILD!!!
                            Smoker
                            nocheep: That is an awesome job you did!
                            Hey, is that parked along Buffalo Soldier Trail? Looks pretty familiar
                            Dave
                              nocheepgas,
                              I'm no expert, but did a fair amount of research and some discussion about smokers before taking this project on. As far as uneven heat, that will always be a problem if your smoke stacks are at or above cooking level. Ours were placed below the level of the cooking grates. As far as the fire brick, that was to help properly size the fire box as well as make it last longer. The fire box is always the first thing to burn out on these things, and lining it was to give it some additional longevity. As far as the grill, the lid on it seals pretty well and is intended to be used seperately from the smoker. You could close all the dampers to capture heat in the smoke box, fire off some steaks or burgers on the grill, then continue smoking in the smoke box. Or alternately when the rest of the meat is done, go ahead and grill at will.
                              The damper control between the fire and smoke boxes (unique to our build, as far as I know) should allow for some serious control of the heat issue.
                              Hope this helps.
