Welding table build
  • Welding table build
    After thinking a while on what would be an ideal table for my needs, I finally got started. Top is 4'x 7' x 1/2" plate, flattened. The slots will allow me to get a clamp on 85-90% of the table.4" x 5# C- channel will form the perimeter and cross supportsThe 3" square cut-outs are for the middle legs and will act as a receiver for my grinder, vise, and bender. Outer legs are 5 x 5 x 3/8"which I found in the scrap section of the steelyard. Too good of a deal to pass up. Brackets on legs are for the wheels. There will also be levelling feet at each leg. Should have it buttoned up this weekend. I am building it upside down and will flip it with either a chain hoist or forklift.
    It looks like you are on your way to having a fine table. I like the acme thread for the levelers. Now I have a reason to keep the 4 8" long pieces that I was getting ready to toss out. Thanks for the idea.
    Nice work.
      Nice.
      How did you make the cuts in the top?
        Can you tell me what the width of the slots on the top are? I'm guessing it's a standard dimension to accommodate clamps. Thanks.
          Originally posted by Jack Olsen View Post
          Nice.
          The fab shop I got the plate from laser cut it for me per my drawing
            I will measure tonight
              Hey Scott. Looks to be a nice welding table. I can't wait to see the P&S plaque finished.
              Nick
                looks real good so far
                  S & P, I take it the studs and nuts worked out for you?
                    So far so good. Soaked them in thinner and then the wire wheel and they were like new.
                    Upgrading the breaker to 100amp tonight so I can get this wrapped up this weekend.
                      Thats a nice looking welding table, great job.
                        The slot width is 1.25". length wise, I figured out where my supports were going to be and the throat depth of the clamps. If need be, I can also use some all-thread and other material to span 2 slots.
                          The table is done. Finally heard the fan kick in on the 350 as I was running pretty hot on the frame. I only did small welds and not many when I attached the top to the frame to minimize the chance of warping the top. My neighbor came by and offered to help flip it, after grabbing an end and tugging on it, he bowed out. Using the chain hoist and pallet jack, i had it turned over in about 15 minutes. Looking forward to using it
                            Good looking table. Nice work.
                              That is a very nice table. I also have to move or turn my stuff by myself. You would be surprised at what you can move if you think about it for awhile.
