Polaris Ranger Snowplow Build
  • Polaris Ranger Snowplow Build
    Just got done with this last weekend for a guy. Thought everyone might like to see some pictures.....
    Plow pics # 2
    Here's some more....
      Plow Pics #3
      last ones...
        Nice just made mine....
        I dont think my atv could have lifted that one! That is built HD, curious to where you got the rotater for the blade? How much and how strong is it?
        Kevin
        Lincoln ranger 305g x2
        Ln25
        Miller spectrum 625
        Miller 30a spoolgun
        Wc115a
        Lincoln 210mp
        F550 imt service truck
          The guy I built it for got the rotator off of eBay - about $400 shipped. I think you can probably find them cheaper. So far it seems to be holding up very well as we've had a bunch of snow. He's been pretty much plowing snow for all of his neighbors since I got it done so it's seen a lot of use already. I think my only concern with it is the size of the battery in the ranger. He may need to eventually get a bigger one or add a second.....
            Battery Thought that might be a probelm....
            I wondered how much the battery would hold. I have considered using an air cylinder and a tank. Simply charge the tank go plow and return. I use my atv near my house, I already have a plow on my truck. How much did the blade weight after you were completed?
            Kevin
            Ln25
            Miller spectrum 625
            Miller 30a spoolgun
            Wc115a
            Lincoln 210mp
              Kevin
              So far the battery is holding up, but it is pretty new too. Not sure how it's going to act once it gets a little more age on it. I know the winch on his 4 wheeler sure drains the battery down. Din't get a chance to weigh it. Got it done and mounted and he was here to pick it up before I even had a chance. The blade and the mounts one guy can handle, although it is tough. The power pivot weighs about 30lbs.
                Very nice Willy. Well thought out.
                  Great looking blade. I bet it holds up way better then the ones you can buy at the box stores.
                  Stickmate LX 235 AC / 160 DC.
                  Clarke 180 EN Just in case
                  Spectrum 375 X-Treme.
                  Milwaukee 14" Chop Saw.
                  4 x 6 Horizontal Band Saw.
                  Projects and Misc Albums
                  http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
                    You did a great job, I am curious as to how thick your blade material is. I just finished taking my old riding mower snow blade that was 42" long and extended it out into a 60" blade to put in front of my Chuck Wagon. I used 1/8" thick plate and heated it in order to bow it. Got it done but took a little while and some persuasion.
                      Thanks - the blade face is made from 14GA....
                        Very nice job Willy. I fix a lot of blade set up in the winter where I work.
                        One customer had a real nice set up with 3/16 UHMW bolted to the ribs to replace the steel blade. Helped with the weight at the front of his pickup.
                        If you have any other projets to share, I'de like to see them.
                        Thanks.
                          Thanks.
                          Thanks for the reply - appreciate it I'll PM you some of my other projects....
                            Right on.
                              ya I have to agree with the people hear that looks good and should hold better then the store brand
