making a mild steel plate convex
  • making a mild steel plate convex
    I'm working on a project in which I have an 1/8 inch oval shaped steel plate that I need to put a slight convexity in from top to bottom and left to right. Don't have any special equipment though except a press. Any ideas?
    You need to find someone with a heavy duty english wheel.
      Heat the center with an oxytorch until it is cherry red then use a sponge full of water and cool it rapidly. This will cause the plate to bend. The metal where it is cooled rapidly shrinks, drawing in the sides. Repeat until you get the proper bend.
        An English wheel would be ideal as long as there's no scale on your material . . . unless the anvil (small wheel) is hardened. Are you near Dayton, OH?
        How smooth / consistent does the surface need to be? You could also hammer the center of the plate against a hard surface, lots of small hits. That will thin the material, making it expand in length. Since the outside is constrained, the center will bow and create the concave surface you want. A torch will also work, but you need to shrink the outside of the plate, not the inside, or you will just cause it to buckle.
        Jim
          How about putting it on a shot or sand bag and hammering to get the shape you want? Mike
            Grind the shape you want into a stump - like a bowl.
            Place steel over the whole, hit with hammer, repeat...........
              Ive seen this done, amazing what some people can do with a wood / rubber / rawhide mallet, and a sand bag. Oh and a lot of patience!
                I think it would depend on the thickness of the plate. For 1/8th it would work. For 1 inch, no chance.
                  Just get a bigger hammer!
                  http://www.ent.ohiou.edu/~raub/manuf...ng/forging.htm
                    1/8" steel is difficult to hammer form. Give it a shot sometime.
                      Maybe Harbor Freights sells these.
                      http://www.youtube.com/watch?v=77IN6UhGSZE
                        This bulldog is roughly 30" tall and across and is made of 10 gauge hot rolled. It is raised in the center about 2 1/2". I did it with a large rounding hammer while cold on a block of wood. I just raised one end and would hammer down on the section that was right above the wood, or set it between two blocks and hammer down in between them. Lots of lighter hits will net you a better shape than hard hits.
                          That seems like a pretty good idea,It seems like it would make it pretty easy if you heated the area dull red before hammering .A gas cylinder cap makes a nice round hammer with a handle welded to it.Mike
                            Recycle the endcap from an old unserviceable propane or air tank? Just look for one with the approximate curve you want.
                              "That seems like a pretty good idea" - Thanks.
                              That's probably how they would do it here -
                              http://www.metalmeet.com/forum/index.php
