Plasma tracer/copier
  • Plasma tracer/copier
    Does anyone have any information or ideas on making a parallellagram style of manual tracer/copier for a plasma setup. I can't afford a CNC table but want the ability to trace a template and then have it scaled for the tourch thru a set of articulating arms. Seems I remember a set of adjustable linkages that articulated so one end follows the other but can't think of the name for the life of me. All I can think of is the spring loaded boxing gloves in cartoons. This is something I want to make with adjustment so on one side can be traced and the other side can be scaled for the plasma gun to cut out 2x size (or 1/2 size). I will figure out how to turn on the gun etc. just need help with the linkages.
    Thanks in advance.
    Hypertherm Powermax 45 PLASMA'r, Lincoln SP-100 MIGGER on gas, Lincoln 175 AC/DC Sq Wave TIGGER, Lincoln 225/125 AC/DC STICKER, 7" x 12" Horiz/Vert Band SAWER, Central 16" - 16 speed Drill PRESSER, Sanborn 3HP 20Gal Air COMPRESSOR, Dayton 9" disk - 6 x 48 Belt SANDER, Sears 8" Pedestal GRINDER, Victor O/A Torch BURNER, 150amp service to the 40'x64' Pole Barn - Priceless
    Pantograph. Search on the web came up with many how to build sites.
    MM250
    RCCS-14
      Victor Panograph Machine
      Hey my dad and I took a o/a panograph and hook a plasma torch in it then wired the torch with a remote switch to turn on plasma torch inside the mach. If you want to see a Panograph mach go to page 2 on welding projects look for (Victor Panograph Machine ) By Vernon
        Plasma Tracer - Copier - Duplicator
        You can buy plasma pantograph plans for 20 bucks at
        http://plasma.fix-er-up.com
        It's simple easy to make. 1:1 Duplication
        video here http://www.youtube.com/watch?v=RcaiR...ature=youtu.be
        Its really cool. Just trace what you want to cut. Free hand or by using template.
        When using a template your copy is the exact same size as what you traced.
          Here is a link to a tracer for sale, complete or kit form and they have a pdf with detailed plans.
          Video and details.
          http://www.rottenleonard.com/Plasma-Tracer.html
          Link to pdf.
          http://www.rottenleonard.com/tracer_instructions.pdf
