Brass Chandioler meets a 25' drop!
  • Brass Chandioler meets a 25' drop!
    A nice little project that came in today. A giant 100 lb 4' tall brass chandioler that cost 5 grand in 1984 fell 25' and smashed. It should be a pretty easy fix it just looks bad all mangled. I need to make a new rod that goes up thru the middle for a frame and weld brass tabs on the arms and redrill the holes to mount. The pcs on the left with the blue tape are fine. Hopefully i don't have to mess with the wiring too much...Bob
    Bob Wright
    ouch! good thing it didnt hit anyone... did it "just fall" or was there something to entice it to come loose?
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
      I was first told it just fell. But when i picked it up i was told they use a hook to pull it over to the 2nd floor to change the bulbs so it may have been pulled...Bob
      Bob Wright
        hehehe... sniker sniker. Well enjoy the rebuild.. if you have any wiring trubs let me know, I'll do what i can to help you out.
        Syncro200
        Spectrum 625
        O/A
        54" laminator
        little dog
          With the kind of work I've seen you do, it will look much better than new in no time. Dave
          sigpicJohn Blewett III 10-22-73 to 8-16-07
            Kind of reminds of on those high school physics problems:
            "A giant 100 lb 4' tall brass chandioler that cost 5 grand in 1984 fell 25' and smashed. What was the speed of the chandelier at impact?"
            Ouch! My head hurts...
              Simple to solve for time.
              s= Vo2 (v naught squared) + 1/2 at2 (at squared)
              Where s= distance
              Vo2 = initial velocity squared
              a= acceleration, 9.8 feet per second
              t2= time squared
              25 feet = 0 + 1/2 x (9.8 x 9.8) t2
              25 = 1/2 x 96.04 t2
              25= 48.02t2
              .52061641=t2
              .721537532=t
              It takes .7 second for the chandelier to fall 25 feet. I don't know how to figure out what the velocity was at impact.
              Millermatic Passport Plus
              Millermatic 200
              Millermatic 350P with Python
              XMT 304 /w S-64 feeder and 12VS
              Dynasty 300 DX
              Thermal Arc 400 MST
              Premier Power Welder for my trail junk.
                E=mc2
                25 ft/sec. should have been the velocity @ impact. In the first second, that chandelier would have accelerated to =32 ft / second, so 25ft in one second should = 17mph...? I think this is right. It failed Physics... was too busy chasing the girls getting 'A's in the subject...
                So with that all said and done, how much did it weigh at the time of impact? hehehehe..
                Syncro200
                Spectrum 625
                O/A
                54" laminator
                little dog
                  I'm not sure about everybody's math, but assuming crawler's calculations of time are correct -- if it fell 25ft in 0.7 secs, then wouldn't that mean it would have fallen 36ft in 1 sec? (25ft/0.7sec = x/1.0sec; 35.71ft/sec=x)
                  Now I'm gonna be having slide rule nightmares again
                    Well, keep the slide rule handy cause Im wondering how much damage it can do on a human scalp at 25ft/.7sec vs 36ft in 1sec or whatever speed it was going
                    Ken
                    Hobart Handler 187
                    Dewalt Chop Saw
                    4" Air Grinder
                    Die Grinder
                    Rigid Drill Press
                    Kellogg 10hp Air Compressor
                    2009 FXDC
                      I dont believe its possble for that to occur in the first second of freefall. it would have to be less than 32 ft/sec.
                      Syncro200
                      Spectrum 625
                      O/A
                      54" laminator
                      little dog
                        For pete's sakes...
                        This is great and reminds me of a great hunting camp story! My math is good and I took both Cal and Phys in college and for some reason unknown to man accelerated very well and sucked miserably every where else with the exception of lunch. In any event and not related to the aforementioned, I a-long with long time hunting friends were debating ballistics in front of a cozy fire in the North Eastern woods of Oregon on our annual deer hunt. The discussion was very involved and even heated at times as we challenged each others wits. Dead front, mid and down range energy along with flat trajectory and muzzle velocity were all taking a serious beating along with the camp growler (the hole in the dirt behind the big tree) as we just finished a hardy helping of wilderness chili stew. While I argued that my 270 was the gun of choice for our location (being flat and often requiring a 150 to 250 yard shot) others argued that a 30-06 or even the age proven 30-30 was a better choice in the event a tree were to jump in the way. And of course you always have the Tim Allan guy there with the 300 Win Mag in case some grizz got of course and darted down from Canada or Alaska. Somewhere into the second hour or so of this wonderful debate, I noticed Randy (one of the guys son) wondering just outside of the campfire lightly tapping two sticks together. At the time Randy was about 11 years old and a gifted shot with his 30-30. I wasn't sure just exactly what he was doing but surmised he was snipe hunting or perhaps warding off any sasquaces that may be lurking around the area. I decided to put my end of the debate on hold as I figured these guys had a enough steam to keep the momentum going in my absence and pay a visit to Randy who at that time was attempting a double tri-fold smore. I was curious about the stick banging as he was very methodical in his delivery. Not to insult him I first asked him if he would share his newly formed smore with me. He agreed and as we both looked at his new creation he not I, realized that perhaps a new debate could be formed on the best way to consume this monster smore. Since we were in the neighborhood of the previous debate I posed the question. "Randy, I noticed that you were banging two sticks together back there by the fire. What was that all about"? "Oh he says" with an uplifting smile, "I was just wondering if the deer on the other end gave a hamster's As~ about your math"? In short we all tend to pass the obvious to strike a debate with our fellow man of the cause or maybe better understood in this case as the delivery. The deer really doesn't care about how he was killed, all he knows or knew was that he was or is in very deep doo doo and could care less about our debate as we enjoy him with our garden salad and baked potato's.
                        All the calculations, speculations and inquires regarding this lamp brought me back to that night and if I can just add on last thing. In the unfortunate event someone had been under that lamp when it fell, they could give a Hamster's as! about the math.
                        Just fun guy's
                        TacMig
                        We depend On:
                        Burco/Koco | Onan | BobCat
                        We belong to or support:
                        American Welding Society
                        The Welding Institute
                        Anderson & Co. LLC
                        Metal Cr
                        afters
                          I had to correct my errors. My original problem, I used 9.8 for acceleration. 9.8 meters/sec is correct, but since we're using feet, this needed to change to 32 ft/sec. Also, had to correct the formula. We don't use Vo^2 (v naught squared). I guess my memory is not so good from high school physics in 1982...
                          Here is a good reference I found on the internet.
                          http://mathforum.org/library/drmath/view/56288.html
                          Originally posted by crawler View Post
                          **** Below is the correct version ****
                          <<<Use this formula to determine how long it will take an object to fall to the ground.>>
                          s= Vo (v naught) + 1/2 at^2 (at squared)
                          Where
                          s= distance
                          Vo = initial velocity
                          a= acceleration, 32 feet per second
                          t2= time squared
                          25 feet = 0 + 1/2(32) t2
                          25 = 1/2 x 32t2
                          25= 16t2
                          1.5625=t2
                          1.25=t
                          It takes 1.25 seconds for the chandelier to fall 25 feet.
                          <<To calculate terminal speed when it hit the floor:>>
                          where
                          v= velocity
                          Vo= initial velocity
                          a= acceleration (32 ft/sec)
                          t=time
                          v=Vo + at
                          v=0 + 32(1.25)
                          v=40
                          Velocity of chandelier hitting the floor is 40 feet/second.
                          Millermatic 200
                          Dynasty 300 DX
                          Thermal Arc 400 MST
                            hehehehe, I kneew that! I was just seeing if you knew!!
                            something didnt seem right about the distance to the floor, but hey, that sure was some tasty deer!!!
                            Syncro200
                            Spectrum 625
                            O/A
                            54" laminator
                            little dog
                              I'm just amazed that someone took the trouble to calculate it!
