Aluminum Case
  • Aluminum Case
    Guys I have an aluminum case here that needs a couple patches. I don't see a problem with the patches but the guy wants diamond plate added to cover each side. It is 10" X 18" and aprox. 1/16 thick.
    With it having to open and close on a hinge, I'm trying to figure out if there will be too much warping when trying to weld all the way around the plate on the outside.
    Here is a short video of it.
    What do you think?
    http://www.youtube.com/watch?v=se3dTgrVDBg
    I think I would just glue some .040 diamond plate to the sides and forget about trying to weld it on.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
      Or.......use some soft aluminum button head rivets. Those might look nice.
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        yes alum. rivets
          Yea the rivet option sounds like the best idea. It has rivets in it now and they look to be sealed with some sort of plastic.
          The holes came out ok. The inside will have foam for the pistols, I'm pleased enough with the outside. Check it out if you like.
          Thanks for the replys.
          http://www.youtube.com/watch?v=an-9Ozpcj3c
            How much are you going to charge him?
            For $200 he can get a new case made from aluminum diamond plate with the foam interior.
            Miller Syncrowave 200 W/Radiator 1A & water cooled torch
            Millermatic 252 on the wish list
            Bridgeport Mill W/ 2 axis CNC control
            South bend lathe 10LX40
            K.O. Lee surface grinder 6X18
            Over 20 years as a Machinist Toolmaker
            A TWO CAR garage full of tools and a fridge full of beer
            Auto shades are for rookies
            www.KLStottlemyer.com
              How did you fix it?
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
                Skip one day and look what happens
                I would'a slapped that diamond plate on there and welded it up in a heartbeat. And most definetly took his MONEY
                Rivets.... the guy came on here (a WELDING forum) to ask about welding and he got advised to rivet!!
                He obviously found someone who knew what they were doing.
                Miller 30-A Spoolgun
                Miller WC-115-A
                Miller Spectrum 300
                  Originally posted by monte55 View Post
                  How did you fix it?
                  Still waiting on an answer. If he brings the plate, guess I'll end up welding it if thatís what he wants.
                  I think it's fine with the holes fixed. The rivets in it now have some sort of plastic sealer involved and there is a seal where it closes. It will be weld a few seconds and cool with a wet rag then repeat. Takes forever.
                  Its a strong enough case for guns, but its a fragile case when welding on it. So far there isn't one grounding clamp mark on it, but that could change in a hurry.
                  Has nobody done anything like this? I know aluminum welds can shrink around 6 percent so I'm still concerned about this thing opening and closing right.
