Angel wings
  • Angel wings
    This is sort of a CNC or metal shaping or welding thread ...
    or all of the above.
    I am making a pair of Angel Wings for the upcoming Christmas Program. I'm cutting the wings out of foam on the CNC.
    While the router was running this afternoon I made the harness. Sort of an R-3 for wings. lol
    Bead roller pic. is a little too fuzzy to tell what it is. But, if you've seen one HF bead roller you've seen them all.
    Used the press & a scrap piece of strap iron to punch out the harness belt slots.
    This is where the welding comes in......I welded the brackets to the harness. lol
    The aluminum tabs will fit between the foam layers & get screwed to the brackets on the harness with self tapping screws so the wings can be positioned right.
    That is really neat, what kind of CNC is that? Is it a router or some other kind of cutting device?
    "The only source of knowledge is experience." Albert Einstein
      Thanks Diverdude. It's a router I use in my sign business. I've had it for years,but just upgraded to the 3-d software.
        that is cool
        i really would like to get or make myself a cnc router and 1 for plasma
        hmmm? could you use the one you have with plasma aswell or is just for routers only?
        gary...
          What 3d software did you get? I have Aspire from Vectric
          Nick
          Miller 252 Mig
          Miller Cricket XL
          Millermatic 150 Mig
          Miller Syncrowave 200 Tig
          2-O/A outfits
          Jet Lathe and Mill
          Jet 7x12 horz/vert band saw
          DeWalt Multi Cutter metal saw
          Century 50 Amp Plasma Cutter
          Propane Forge
          60" X 60" router/plasma table
            Originally posted by glh View Post
            that is cool
            gary...
            Yup, the servos will move anything you attach to them. Possibilities are limitless.
              I have Aspire V2 also. These wings are the first job for the new software. It's a pretty cool program.
                Yeah it is cool. It can do so much it's hard to keep up unless you use it every day. I used the 3d to cut my rotor blades for my ultra lite heli project. Did you have V Carve and then upgrade or just buy Aspire. I got V carve in 2007 and in Jan of 2009 paid the $900 to get Aspire while they had the promo on. Had I waited two more weeks it would have cost $1450. I think new is $2000.
                Nick
                Miller 252 Mig
                Miller Cricket XL
                Millermatic 150 Mig
                2-O/A outfits
                Jet Lathe and Mill
                Propane Forge
                  No, I was using the 2-d program that came with the CNC. Basically just a driver program. I do all my designing in Flexisign & import DXF files to be cut. Aspire is all new to me. It looks like it has all kinds of potential.
                    What impressed me is that you can design your own 3d projects in Aspire. . They have a lot cheaper program called Cut 3d but you can't design 3d. If you have to start buying 3d files anywhere from $10 to $50 each.....that can add up real fast.
                    Nick
                    Miller 252 Mig
                    Miller Cricket XL
                    Millermatic 150 Mig
                    2-O/A outfits
                    Jet Lathe and Mill
                    Propane Forge
                      Yea, I'm going to give that a try when I have time.*I designed this wing in Flexisign & imported it as a DXF file mostly because I'm under the gun to get this stuff done and I'm familiar with Flexi. I've got a few other things to do for the same project that will be a real challenge for a newbie Aspire user. I'm sure glad they have those DVD tutorials.
                        They have the most informative and the nicest members of any forum I've ever been on. I've never seen an arguement or a bad word. Everyone is always willing to help. They're great. I think it's because they are busy being productive and don't have the extra time to be a jerk.
                        Nick
                        Miller 252 Mig
                        Miller Cricket XL
                        Millermatic 150 Mig
                        2-O/A outfits
                        Jet Lathe and Mill
                        Propane Forge
                          Yes, they've been very helpful to me. I've got some projects coming up I'll need more or their help I'm sure.
                          Tonight I glued the pieces together. To make room for the aluminum mounting tabs, I marked out where they go on the foam & used a heat gun to shrink that area. Then I sprayed great stuff on the mating surfaces & squeegeed it to knock down the foam. Laid the aluminum tabs in place, laid up the parts & carefully weighted them down with cinder blocks.
                          As Norm Abrams would say.....''I'll let them cook overnight''. lol
                            are you mass producing them.
                              Nope, these are 1 off items for the upcoming Christmas Program @ Church. I've got a couple other things I'm doing for the play also, I'll post as I get them done. Not a whole lot of welding involved but I thought since it's Christmas & this thread is already here......
                              The last item will be a full size camel. I'm saving that for last because it's not needed until the play dates & it will be by far the most challenging. It will be an outside model, so I may need to fab some structure & a base so it will hold up to the wind & elements.
