Aluminum dump
  • Aluminum dump
    First off thanks Miller for the tape! A customer brought by a project that may require its use ...WOW six broken crossmembers and about ten feet of worn-out floor.
    Mike
    The fruits of eight hours of hard labor. UGLY hu?
    Mike
      hi mike looks just like the night mare i fell into last year except mine had all but one broke and no floor left under the liner took way to long to do
        This one isn`t going too bad yet , but who knows? The only thing I could do without is the tar under the floor that has to be removed in order to get a satisfactory weld! Asphalt trucks are filthy underneath to say the least.
        Mike
          your right asphalt is bad to work with Ido a lot of dumps that hall asphalt thank god some one invented fire hope it welds up good for you
            Thanks Garth. The bright spot to this is that the new floor and crossmembers should weld up pretty well. It`s usually a challange to get origional crossmembers clean enough to weld up .
            Mike
              Mike
              Yet another reason my truck will never haul that stinky black goo!
                Black gold Don..black gold.
                Mike
                  Eight more hours, one more blister, one less grinder!
                  The first day is such a drastic change it seems like all kinds of progress is being made, but then comes the slow grunt work with the grinder(may it rest in peace).
                  Mike
                    Grinders. R.I.P.
                    Wheels , what brand of grinder are you using ? And is that an Ohio plate on that truck ? Dan
                      Yes Dan it is from the Buckeye State, we are about 40 miles east of Columbus, and the recently deceased grinder was a Dewalt Dw400.
                      I knew the 400 was too light duty for what I get into, but I put off getting a replacement. After the fatality I rushed to the local box store and picked up two DW28402`s to fill the void.
                      Mike
                        Some progress after a two day waite for materials. Roadway dropped the ball on shipping and the plate for the floor is also a few days out, durn it!
                        Mike
                          lookin real good hope your floor plates get there soon hope to see it when its done thanks
                            Grinders .
                            I have found that Metabo's last good , their W7-115 Quick is a good grinder. thats all I use , it has taken everything I have thrown at it . if you get a chance try one . Dan
                              Dan,
                              I see your in nw Pa. Perry Mill in Erie is a good place to buy Metabo.
