Meat/Utility Trailer
  • Meat/Utility Trailer
    This is the first trailer I built with a walking beam axle. It turned out alot heavier than I wanted but tows really well. Does anybody know of rotating hitch assembly that could be added?
    Go with a pintle set up and you should be fine.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
      may i ask what is walking beams please
        Walking Beam Axle
        Thumpergman--The best way I can think of a walking beam is, a tandem wheeled trailer that revolves around a single axle. Thank-You Fishy Jim for the pintle hook idea--that should work really well.
          nice little atv trailer.
            You can also make a rotating pintle mount pretty easily as well if you need even more off camber ability. The military has some like that you could use for ideas.
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Smith O/A rig
              nice trailer, excellent work
              Matt
              Syncrowave 200
              Thermal Dynamics Cutmaster 52
              Smithy Midas 1220 Lathe- Mill
              Bandsaw- 20 yr old Harbor Freight type
              Speedglas
                one similar to this
                they make one for the hoop side as well, a source just escepes me at moment.
                http://www.northerntool.com/webapp/w...Product%20Page
                they used them on the old military jeep trailers. I have a pintel on my grizzly and also my Rhino they are muchbeter than a ball mount.
                Every question in life has an answer of
                YES OR NO
                Maybe = NO
                Keep life simple and enjoy it!
                  Thank you guys for all the advice and Thank You ABYSS for the link. I will be going with the pintle hook setup. Thanks again.
                    no worries
                    the pintel is superior if you can get the spring setup for the hoop side you are unlimited on rotation, makes for unlimited articulation.
                    YES OR NO
                    Maybe = NO
                      Sorry for late response. But here is the hitch I am planning to put on my off road trailer. 3 Axis and comes in kit or finished form.
                      http://www.off-roadinternational.com/tough.html
