2050 Plasma cutter
  • 2050 Plasma cutter
    Has anyone used the Miller 2050 Plasma cutter ? I am looking for a plasma cutter for my shop . I have read it will cut to 7/8" , this is thicker than I use normally . I use 1/2" , 5/8" often , and 3/4" once in awhile , the cutter I was looking at goes to 5/8" . Being a pipefitter , I use a torch mostly on the job and do not have a lot of exprience with plasma cutters .
    Tools to Men are like Shoes to Women you can never have too many .
    Miller XMT-304
    Miller Spectrum 2050
    Miller 10-E Feeder
    Hobart 175 Handler
    Lincoln AC225
    And assorted others
    You WANT a plasma cutter that is rated for a bit more than what you plan on cutting anyway. The faster it cuts your material, the better your cut usually is.
      I only wish I could afford one!
      Save our species! Lower metal prices!
        plasmas
        If you dont plan on doing alot of work with the unit i'm in the habit of using zip cut blades theve vitually eliminated my use of torches in many ways nice straight cuts and minimul affect to the material
        smokin ana grinnin for 20 years
        Owner MARKS MOBILE WELDING
        trailblazer 302
        hobart suitcase mig
        miller 30a al spool gun
        laramy plastic welder
        brocco cutter
        pipe beveler
        all walter hand tools
          You said you use zip cut blades. Are you referring to something like a rotozip type cutter? I'm not quite sure what your referring to, but I'm interested to see if I can apply it to what I do.
          Tom
            I use one all the time. I hope to by one here in the near future, because renting one is about $40.00 a day. I would suggest going with the biggest one you can get or have power to run, just in case you need it. The 2050 is the biggest one that will run on my Trailblazer.
            SQUIG - Are your zip cut blades used on a grinder. If so I call them slitter disks. I ask because when I cut on thicker metal, the grinder get really hot. I have burned up two 5 1/2'' grinders.
            sigpic
            Miller Trailblazer 302
            Miller 12 RC wire feeder
            Miller HF 251D-1
            Miller 175 wire feed
              zip-cut blades
              Walter makes these grinder blades and there real slick,they are 1/16 thick so they dont heat up or use a lot of material width.I beileive they are called razor blades in the US the nice thing with them is they really last a long time especially if you dont force them and after you make your cut your good to go with a plasma you would have to clean your joint anyway!
              trailblazer 302
              hobart suitcase mig
              brocco cutter
              pipe beveler
                Razor
                Squig your correct thay are called Razor blades.And your right razor work real nice but you can always use the plasma for more detailed work.I have the 2050 on my trailblazer 301G and its a nice thing to have around.Cuts steel & aluminium like a dream.
                "Molten Metal Fusion Technician"
                  I've never heard the term razor blades to describe grinder cut-off wheels. But I guess it's out there. I've heard zip disks, though, but usually just cut-off wheels.
                    the older style of cut blades were1/8 these are1/16
                    trailblazer 302
                    hobart suitcase mig
                    brocco cutter
                    pipe beveler
                      Thanks guy's
                      Thanks for the info guys . We call them wafer wheels up here , but you better have a real good grinder to run them . I have brunt up as many as four Dewalt 4.5" ginders in a day running wafer wheels at work . We use them to cut pipe in places you can't use a torch or for materials you can't burn ( SS , Al. or copper ) . Very hard to get companies to send out a plasma cutter , most are afraid they would not get it back . In my own shop I use Metabo grinders , have had my present one for about six years now and use it almost daily ,it is just starting to get weak on me . Will buy a new one and use the old one to run wire wheels . I was looking at the plasma cutters and figured bigger is better . Dan
                      Miller XMT-304
                      Miller 10-E Feeder
                      Hobart 175 Handler
                      Lincoln AC225
                      And assorted others
                        Dan, I am a factory service rep and I may be able to help you out with a demo. Give me a call at 920-831-4854 and I will see if I can get you a Spectrum 2050 to demo. Our District sales managers get involved when we need to demo equipment and they should be able to set something up at a local distributor or even at your shop. The Plasma is definitley faster at cutting than a grinder. Remember, if it conducts electricity, a plasma arc will cut it.
                          hey miller scott, could i demo a machine like the sync 200? I'm up here in canada Eh!
                            Shop under repair .
                            Scott , I will take you up on your offer as soon as I get my shop repaired . Lost a wall in this last wind storm , so it looks like its time for a new shop . No insurance on the building but didn't lose any tools or equipment when the wall came down . I learned a valuble lesson , when building on a budget be very very careful where your lumber comes from . Two of the wooden beams I used had powder post beatles in them , by the time I discovered them it was to late . Was planning on a new shop this year anyway . Dan
                            Miller XMT-304
                            Miller 10-E Feeder
                            Hobart 175 Handler
                            Lincoln AC225
                            And assorted others
                              ? for Miller Scott
                              The 2050 information I have been reading says it will cut 7/8" steel but it did not say what it would sever ?
                              Dan
                              Miller XMT-304
                              Miller 10-E Feeder
                              Hobart 175 Handler
                              Lincoln AC225
                              And assorted others
