control arm tube insert welds
  • control arm tube insert welds
    here are a few pics of the tube inserts I was having trouble with the threads gauding.....I used the anti splatter spray on em' & it worked like a champ!
    O! tig welds were done with my Maxstar 200 STR 1/16" root let it fully cool & then a 1/8" cap. As you can see some of the welds aren't capped yet----ran out of Argon
      Nice welds!
      Why did you make the arms adjustable?
        great looking welds. what are you making ? do we get a full pic of the complete toy ??
        don't ya hate it when you run out of argon in the middle of something.
        i got a backup 80 tank to help keep that from happening. when my big tank is getting close to empty i pull it off and use the 80. this way if the 80 runs out be for i go for a refill there is still a little left in the big one.
        although probably not enough to do all the caps.
          Adjustable control arms just sounds better I guess? , I will take more pics along the way & post them up.
          Dave---not to bad for a "stick" machine hugh? Thanks for all your help BTW getting me all set up to tig on the STR!
            I am building a 4-link rear & 3-link front coilover suspension on a 79' scout.
              Nice work!
                anytime i do a weld like that i use "never seize" or some call it "anti seize"......nice work i have a 1972 scout i'm going to do a spring over axle conversion....
                  The weld shrinking compresses the outer thread. After welding run a tap through it.
                  David
                    I had the same problem when I did some on my tie rod and steering link. Ran a tap through them when I was done welding.
                      Would it help at all to heat up the threaded collar to expand it before welding?
                        I left the rod end threaded into the tube insert with some anti-splatter spray on it, welded the root then let it fully cool then welded the cap and it threads in and out like BUTTER!!!!!! No sticking at all!!!!!!
                          NIce Job where did u get those inserts I could use some do they make left and right hand thread?
                            http://chassisengineering.com/shopDe...ProductId=1572
                              http://www.ballisticfabrication.com/...pters_c_7.html
