Rigs getting bigger/more toys
  • admweld
    started a topic Rigs getting bigger/more toys
    Just added another diamond plate box bringing the total to 5.This one is on the p-side top 48"x18"x18"barndoor.In the front 2' left open,there is going to be a Cox hand crank 1/2"air reel waiting for it to get here setting it up with 150' of hose to run my new 3/4"IR gun and air arcing.
  • lanceman73
    tanks
    Originally posted by Sberry View Post
    I have 2 100# lp tanks under the truck.
    Where are the tanks?
  • lanceman73
    1" impact
    Of coarse! You can't get truck tires off with a 3/4". Have you checked out the service truck that I built?
    Originally posted by metalmeltr View Post
    I probly would too if I worked on heavy equipment but on a car or light truck ther isnt mch use for one, does any one have a 1" impact
  • admweld
    What is the TI?
    Titanium composite IR Impact gun, lighter,more power then standard guns.Basically top of the line.
  • metalmeltr
    What is the TI?
  • J hall
    Originally posted by Portable Welder View Post
    I have the big & bad 1/2" TI Ingersorand impact but its useless on the heavy equipment.
    Ny compressor kicks in at 140psi and kicks out at 180. the TI will turn some bolts at those pressures
  • admweld
    few final pics
    A look down of the stairs in my shop.And a close up of the regulator,pipe union,flex hose to reel.
  • Sberry
  • admweld
    All plumbed in i,ll snap a few pics later for ya guys.Thanks for the compliments on the rig.Sorry, Portable all blue in my world.Ialso have seen my comp. struggle to keep up.Hoping this helps but won,t know till i try.Need to try the HT plasma of the 3ph. side of the BB402D also, all wired up just never tried it.Can we add another tank somewhere Portable for more air storage?
  • c wagner
    Originally posted by admweld View Post
    Thanks there locked even when the trucks locked in the shop overnight.
    It's unfortunate that it has to be that way.
    Nice looking rig!!!
  • Portable Welder
    Adam, Your down fall is probably your compressor.
    I was cutting a 12 yard dump box and the pintle hitch off a truck yester day evening and had to keep waiting for the compressor to build back up so I could keep air arcing and the customer was getting a little irritated with me standing around while being on the clock at $ 80.00 Hr.
    I dont usually have that much continuouse air arcing and usually my compressor does fine but she was struggling last night.
    I need to get the bigger hose on my truck as well as a 3/4" impact, I have the big & bad 1/2" TI Ingersorand impact but its useless on the heavy equipment.
    Good luck Adam, As always your truck looks great.
    The only problem with your truck is that its not red.
  • admweld
    Originally posted by ProudBlackMan View Post
    Rig looks good Adams, best to keep them boxs locked up tight!
  • J hall
    I use a 1" more than my 3/4. But My IR 1/2" ti is still used the most.
  • metalmeltr
  • Sberry
    I actually use my 3/4 as much or more on my truck as 1/2.
