BBQ Pit - Material
  • BBQ Pit - Material
    Hello,
    I am new to both the site and to welding.
    I have a small part time bead blasting company in MA, North of Bean Town, and purchased a MIG a while ago and want to try it out on a project.
    I was thinking about building a BBQ/Fire Pit.
    My questions are:
    Can I use black iron pipe to frame it up ?
    Will the pipe weld OK ?
    Can the pipe be bent into a circle OK ?
    I was thinking of using the pipe to form three circular frames and tie them together using 3/8 rods at 15 to 30 degree increments.
    Add some kind of heavy duty screening and you have a Fire Pit, alt use BBQ Pit.
    What's your thoughts ?
    Any help will be appreciated
    Thanks,
    Black pipe hasn't held up to support a load in a fire in my use.
    I used it to support my charcoal maker and have 2 nice curved pipes now.
    here you can see how there were to begin with.
    edit: here is a link to more info on the charcoal maker http://www.millerwelds.com/resources...light=charcoal
    www.castandque.com
      The Pipe will weld fine
      Yes it can be rolled- but you need a roller
      I think it will work as a Frame too but back to rolling the circles- need a roller
      I believe Chuck's pipe warped 'cause he basically built hisself a Forge- bend/warp just about any metal with the same gauge as Black pipe.
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Probably so, The 2" oil field pipe I used is holding up, so I will be making some supports out of more of it.
