Ring Roller design
  • etonline
    started a topic Ring Roller design
    Ring Roller design
    I am getting ready to build a ring roller.
    How does the relationship of distance between the lower wheels affect things?
    What distance are yours?
    Ed
  • ed_h
    Originally posted by 67chevelle View Post
    Ed H, that's a pretty slick roller you've got. Similar design to what I built.
    Ed, The drive wheel on mine is 4" and the bottom rollers are 1.5". TO do some tighter radius arches, I think I can get the bottom rollers down to 7-8" apart.
    Mark
    Likewise, Mark. Yes, I guess great minds think alike.
    I'm not sure why I went with the large bottom rollers--just made all three the same, I guess. I really like the idea of the split collars to hold alignment--simple and adjustable, too.
  • ed_h
    Originally posted by etonline View Post
    Ed H, what are the adjustment distances on yours?
    I was thinking I'd start with the first adjustment at about 5" with 3" wheels. And go about every 2.5".
    Ed
    Ed--Vertical adjustmant range in mine is about 5". Horizontal spacing for the un-driven rolls is 10, 15, or 20". These weren't from any calculation. Just seemed about right.
    --ed_h
  • monte55
    Nut shell............I get it
  • etonline
    HF is Harbor Freight DrBob.
    Some of there stuff is a level below China made. But for some disposable tools it will get you by.
    Went there to get chip brushes...walked by the air comp stuff and though **** need a quick chuck so I bought a pack. Third time I released the tool from it, it flew apart...wild hose about took the family jewels. That's kinda HF in a nut shell.
  • DrBob
    Thanks Mark
    I'd never heard the term "piano hinge" before
    Well it's the term my shop teacher used to describe a long hinge of that type.
    I guess some version of it is used on the tops of pianos - I can only play the radio myself BTW I took metal shop in the 1950s so maybe it's called something else now
    I'm building a bench to hold projects for welding with my new MM180 which welds rings around my old Lincoln.
    Another newbie question. I keep reading people buying stuff from a place they refer to as HF - wazzat? (I know I'll kick myself when I hear the answer).
    Thanks for posting the picture of your bench.
    DrBob
  • cliff huxtable
    Lets see some pics of that roller Portable welder.
  • 67chevelle
    DrBob,
    The cart you're referring to is a small roll around work cart.
    The drawer you see is a fold down table that used to be in a mail truck. I used some drawer slides to mount a couple of them under the tops of some carts I built.
    I'd never heard the term "piano hinge" before ( I gotta get out more )
    The hinge is the backside of the drawer, I just didn't take it off before I mounted the drawer.
    The top is 1/4", It's only meant for the light duty stuff.
    Here's a better image of the one I use for my TIG machine
    ( I know.. It's red , both of my MIG's are blue though)
    http://www.shopfloortalk.com/forums/...5&d=1170393416
    Mark
  • DrBob
    Beautiful Work!
    67 chevelle I went to the shopfloortalk forum and reviewed your beautiful project. I got about 5 projects just from seeing the pictures of your shop!
    Beautiful work on the roller. I think I'll start with a welding bench similar to the one pictured. Yours seems to have a drawer supported by some angle stock resting on the square tubing frame. Is it a sliding drawer? What is the purpose of the piano hinge? Is that 1/2" plate on the top? Thanks for any help you can provide! BTW I signed up over at shopfloortalk and used '67 chevelle' as the referring member and got 'invalid referrer'. Maybe I spelled you wrong or put in an extra blank space. DrBob
  • etonline
    Wow 1/2 X 6 by hand...you must have some big arms
    Mind sharing a pic?
  • Portable Welder
    I built a 36" plate roller that I use by hand, it works great Its only been done for a few months so I dont know all of its capacities but we did roll some 1/2 x 6 plate and 36" of 10 gage, obviously not in 1 pass but working it back and forth gets the job done.
  • etonline
    Thanks for the help Mark.
    I was going to use and under bottle jack but after looking at your two different designs.....I'm thinking on top with a all thread might be easier and better.
  • 67chevelle
    Mark
  • etonline
    Thanks Mark & Ed H. Both are very smooth tools. I doubt mine will be that slick.
    That was pretty much my toughts for the side plates to be adjustable.
    Mark how much closer than 14" are you going to go?
    Thanks for the great input guys.
    Later
    Ed
  • ed_h
    Here's another example similar of a shop-built roll bender:
    http://bullfire.net/Roll_Bender/WP_Roll_Bender.html
