My Welding Truck
  • My Welding Truck
    A few photos of my welding rig I can load or unload in about 15 min. I am Miller all the way.
    Looks like it works pretty well for you.
    It looks like it still leaves you with a lot of truck box space.
    How much do you notice the high center of gravity when you have the skid on?
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
      Looks nice! I can't tell from the pics what holds everything in place. Do you pin it after you set it on? One thing I don't like is the acetylene laying down, yes I know it is tilted but it should be upright.
      MM250
      RCCS-14
        Good pictures.Are you not concerned that the boxes are too close to the rear of the welders and block the ventilation?
        2- XMT's 350 cc/cv
        1- Blue star 185
        1- BOBCAT 250
        1- TRAILBLAZER 302
        1- MILLER DVI
        1- PASSPORT PLUS
        1- DYNASTY 200 DX
        1- MAXSTAR 150 STL
        1- HF-251 BOX
        1- S-74d
        1- S-75DXA
        2- 12-RC SUITCASES
        1- 8-VS SUITCASE
        2- 30 A SPOOLGUNS
          I think that is a shielding gas bottle, green tag with silver brown paint, also looks like a flowmeter attached.
          Miller Shopmaster 300 CC/CV AC/DC
          S22A Wirefeed
          HF251D1 High Frequency Box
          Coolmate 3
          Miller Spectrum 625 Xtreme
          Lincoln Idealarc 250 DC CC/CV
          LN-7 Wirefeed
            Looks good
            Ive seen your rig around town several times always commented to my help how good it looks, hope your busiser than we are.
              Truck
              Looks good but why so high??
              If you have a fork truck to lift in and out why not keep it alittle close to the floor, i can understand if you need the room to store matereial but lift it out when your done.
              Railmen
              2007 Trailblazer 302G
              2004 Invision 354MP
              1999 60 series feeder
              2005 Maxstar 200DX
              2007 CST280
              1999 HF 251-1
              older Hobart hefty wire feeder
              Hyperthrem 600
              Maxstar 150S(such a cute welder)
              had and sold........
              2003 XMT 304CC/CV
              1947 Lincoln SA200G short hood
              1963 Lincoln SA200G
              1975 Lincoln SA200G(best machine ever had )
              1970's Lincoln SAE400G
              2 Maxstar's 200DX's
              1 Maxstar 200SD
              CST 280
              2 CST 250
              MM130
              Railmen
                ok
                well now i caught on i see you have two welders on that rig...............
                why the need for two??
                you could save yourself lots of space and fuel cost by maybe running like a CST280/250 off the front of your newer 250, i guess it just depends on how much power you need on the second arc?? or even like a maxstar 200 draw very little and work great.......
                just my two cents.
                i have a TB302 and i have run a XMT 304 off the front and run both machines on 5/32 rod all day once....
                Railmen
                2004 Invision 354MP
                2005 Maxstar 200DX
                2007 CST280
                1999 HF 251-1
                Hyperthrem 600
                2003 XMT 304CC/CV
                1963 Lincoln SA200G
                2 Maxstar's 200DX's
                1 Maxstar 200SD
                CST 280
                2 CST 250
                MM130
                Railmen
                  That is a great set up. Easy on-easy off and lots of space beneath for supplies....
                  Good idea!
                  RoyB
                  Dartmouth, MA
                  http://www.rvbprecision.com
                  Millermatic 185 MIG
                  Miller Diversion 165
                  Purox W200 O/A
                  Grizzly 9957 Mill
                  Grizzly 4030 Metal Band Saw
                  Grizzly 1050 Knife Belt Sander
                  Jet 1236 Metal Lathe
                  TP Blast Cabinet
                    Cog
                    No problem with COG having the dual wheels even pull the forklift in the photo loaded. Previous truck had a flat bed and if I wanted to carry anything over 4 feet had to pull a trailer. Not only can I carry item 8' long I can lock the tailgate.
                      Bolts Down
                      2"x2"x1/4" tube running the length of the truck on each side welder frames bolt to 3/8" bolts x 4 for each welder 80K miles no problem. As for the tank I have heard that they will explode for 40 years but have not had any problems. Can tell you how many jobs I pull up on and there is a guy in the gravel cutting re-bar with tanks laying flat on the ground. With the Spectrum 375 Plasma on board very seldom use it torch.
                        Bobcat Usage
                        just my two cents.
                        Railmen
                        I fabricate and install stair and railing for www.urbanactive.com gyms. Use this rig when installing stair and railing first welder is tacking it in place with a 7018 stick rod and running power for grinder, band saw, hilti drill etc and the second welders is sewing it up with .035 feeder mig gun. If you run accessories from the rear welder with the mig you notice it a lot.
                          Works great for me
                            IC just a thought, I am always looking for ways to cut costs and make things smiple.
                            But if it works then DO IT, as my old boss says..............
                            other then that looks good.
                            Railmen
                            2004 Invision 354MP
                            2005 Maxstar 200DX
                            2007 CST280
                            1999 HF 251-1
                            Hyperthrem 600
                            2003 XMT 304CC/CV
                            1963 Lincoln SA200G
                            2 Maxstar's 200DX's
                            1 Maxstar 200SD
                            CST 280
                            2 CST 250
                            MM130
                            Railmen
                              Service Truck
                              Nice pics of your service truck!
                              Take Care,
                              John
