bad ratio
  • bad ratio
    I get excited about a project and weld without having done a proper test piece.
    Whada get?
    10 seconds of welding and 20 minutes of weld cleanup.
    hee hee hee....welcome to my world
    1) Go to do a short weld, only to find out that someone turned off the gas
    2) Guy who used it last, didn't clean the tip
    3) "Oh, it's just a quick tack", ouch...should've worn gloves anyway
      You mean Im not the only one
      Another thing, dont lean on your welding table with bare skin while welding reverse polarity ::tingles a little::
      Johnny - might be your first but it wont be your last time doing that
        hehe, yeah
          Tingle doesn't sound good! No Tingles. I haven't used flux cored yet so don't know...have not changed polarity.
            I like to spend 2 hours making a bunch of small parts and then welding them mirror of what was needed. Put the drilled holes and brackets opp of what was needed.
            Another time I ran out of gas and was so focused on the though that the motor case I was working on was contaminated with oil that I did not check the gas right away and sooted the weld up and roasted the Tung. Was welding fine then bad so it must be oil! After the 10 wat light over my head flickered on I swapped to the other tank on the Tigrunner. Made some real ugly looking "weld". Still thinking it was oil I heated with with a heat gun and cleaned some more. Still fuggly. Looked at the gas and noted that I hooked up to a C-25 bottle. Good thing no one was looking...
              Oh yeah, I very efficiently turned off the gas like I always do then went back ten minutes later, after doing weld cleanup from first passes, and filled a hole without gas- nice stuff.
              I got by OK in spite of it.
                Isn't tha what bondo is for????
                bert
                  I thought that's what primer was for
                    YEESH!!!!!!!! Don't you know....ANYTHING!!!!!!!!!!!!!
                    You smooth over all your cr@ppy welds with bondo, take a dental tool (or dremel) and "carve" out those "stack of dime beads!!!!!!!!"
                    sorry, still laughing!!!!
                      no no no you run and grab the caulking gun and set the trigger to pulse ,and let er rip
                      give me a call ,and ill come over and show you how to do it
                        I don't have the money you do!!!!! I just have the $20 gun.....no pulse
                          Easy to make a home made pulser for the caulk gun.
                          had a railing in a healthclub break. Came to reweld the failed corner and found that it was only tacked up only where the metal met. I say where as the pipes were cut flat and sort of fishmouthed a little with a grinder. then large amounts of latex caulk were gobbed on and smoothed out before everything was painted. Looked good but you could kick a railing pipe and an end would break free.
                            wow! Look at the rest of the railing, find all the "welds" and you got yourself a good job to make that thing safe!!!!!!!!!!
