Welding Table & some jeep goodies....warning picture fat!!!
  • Welding Table & some jeep goodies....warning picture fat!!!
    Decided to fab up some stuff over the last few weeks!
  • mr2man
    Nice work, it looks good.
  • bamacpl
    Looks nice!!!!
    Yes, I could make you some doors.....They are 1 1/4" x .120 wall & I am using the JD2 tube bender.
  • nocheepgas
    Originally posted by Ultrachop View Post
    Nice work and great photos!! Did you make the bending dies as well??
    Thanks for sharing!
    Tim
    No, I purchased bending dies for a JD2 bender.
  • nocheepgas
    Originally posted by TS-Off-Road View Post
    Using a winch cable to operate a tube bender!
    Scary.
    Not really, My winch is rated @ 9000#, the synthetic cable @ 16,000# the hydraulic pressure on a hydraulic unit is usually 3,000# +-. My winch design has the advantage of torque applied through mechanical advantage gained by the force being applied at a greater distance from the c/l of the bending radius.
  • Ultrachop
    Thanks for sharing!
    Tim
  • TS-Off-Road
    Scary.
  • nocheepgas
    Originally posted by Mr. Clean View Post
    How about a little more info on this tubing bender you mentioned. I would like to see your plans. PM me if you would like, I don't want to high jack this post.
    My bender is a real "Off the Wall" design. I wanted a powered bender but didn't want to spend the big bucks for hydraulics, so I'm building it to be powered by my winch! I have a concept drawing in my photobucket account:
    http://s255.photobucket.com/albums/hh140/rivanisko4380/
  • nocheepgas
    Originally posted by ace4059 View Post
    Nocheapgas,
    where did you get those led lights from?
    I got them here: http://www.roundeyes.com/Products-LED_Lighting.html
    I mounted them differently than they are designed. I beat the mounting panel/tab flat, drilled holes and a countersink (to allow for light dispersion) for the light and mounting holes and riveted them in place. It was a real bugger fishing them up to the ends of the bumper and holding them in place while I set the rivets.
  • Mr. Clean
    Originally posted by nocheepgas View Post
    I like your Jeep tube doors and rockers. Want to fab some doors and tube fenders when I'm done building my tube bender. Here's a pic of my rockers and bumper:
    Modified Warn rockers
    Front Bumper
    Recessed LED Lights
  • ace4059
    Nocheapgas,
  • TS-Off-Road
    Those LED "rocklights" are a cool idea.
  • nocheepgas
    Front Bumper
    Recessed LED Lights
  • bamacpl
    Originally posted by tasslehawf View Post
    On your table, it looks like the casters are tacked on??
    yes, I wasn't sure how the pneumatic tires would work.....? so I tacked then for the trial period, they only lasted a week. I have since swapped them out for some solid ones! Much...much better!!!!!
  • bamacpl
    Originally posted by walker View Post
    Looks good. What are you using for the pivot on your tire carrier. I built one a while back using a piece of cold rolled bar and a piece of DOM but it wants to gall badly, so I will need to cut that section off and weld on a new pivot.
    1" trailer spindle from a tractor supply (Cal-Ranch)
