Bush Hog
  • Bush Hog
    Hey Gang !!
    I am looking at building a small Bush Hog to pull behind my 4-Wheeler.
    All I have at this time is the motor.
    The motor is a 12 Hp from a Snapper riding Lawnmower.
    I was thinking of making something like the deck that is on the mower, but will it work?
    Has anyone build a Bush Hog? All I am looking to cut is Palmetto's in the woods.
    Any Ideas?
    Please pass them along if you can.
    God Bless,
    I've never built a brush deck, but I'll pass along what my experience has been. If you are going to use the 12hp, then is going to have to be a very small brush hog. I have a light duty 60 inch deck with two break-away blades, stump jumper and a 35HP gear box for use my compact tractor. It develops 31HP max on the 540 PTO. That is just enough power to run that mower. More than once I have stalled the tractor with high grass or brush. Anyway, just thought I'd throw some real world numbers out there for you to help with any other ideas. SSS
    Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
    Cat 242B Skid Steer, Challenger (Cat/Agco) MT275
    1 Thessalonians 4:11-12
      Check out Northern Hydraulics for ideas, they sell mowers sorta like what your looking for. If your pulling with a 4 wheeler than it will have to have wheels that will raise it up or adjust the cutting height since you dont have a 3 point hitch. The 12 hp engine is fine for about a 30"-36" maybe. Also I would rig up with an electric clutch so I could shut the blade off with the engine still running. If its a rear mount snapper, most did not have an electric clutch. You could rig up tensioner pulley and a lever that could reach the seat of the 4 wheeler.
      Good luck
      HMW [Heavy Metal welding]
        More power?
        I have an 18 hp two cylinder Briggs inn the garage that is going to the junk yard, as soon as I move the other junk to find it.
        It was off a riding tractor that was scrapped, engine was good.
        You are welcome to it, I am in NE Pennsylvania, if you are close?
          Well, that all depends on what you call close.
          I am in Louisiana.
          So probably not close enough.
          Thanks for the info, I still think I want to make something like this. It does not have to be big. Just big enough to fit between the trees, I need shooting lanes.
          God Bless All,
