Trailer design, links, suggestions....
  • Trailer design, links, suggestions....
    Does anyone have any links for design, parts sources at a discount, etc.?
    I am planning a flat bed utility trailer with 2 3500lb. axles. I want to use tubing rather than channel for the structure to have a stronger/lighter trailer. Planning on torsion axles, led lighting, etc. Size will be 16'x7'ish, enough to allow for the fenders and tires. I was planning on using 2x4 .120 wall tubing for the structure. Questions I would have include proper design of the frame, weight distribution, axle placement (fore and aft), etc.
    Any sources, links or suggestions would be appreciated.
    Thanks!
    Dave
    Hypertherm 380
    I have built lots of trailers, look around here for some ideas...Bob
    http://s110.photobucket.com/albums/n...0have%20built/
    Bob Wright
      try Northern Tool or East Marine
      Both of the companies have considerable parts available. East Marine also calls itself "Trailer Superstore" or something similar. They have axles in just about any length in case you make something odd-sized. I have a cargo trailer and have also made an open 4'x8' trailer. Northern Tool also has blueprints for about $25 to $40 depending on design. Good Luck
        Trailer questions
        I too, would like to know if there is any secrets to designing a flat bed trailer - I think some refer to them as "Landscape" trailers.
        Any how I'd like to build a 12' x 5' bed trailer, with an 'A' frame coupler, and I'm debating tandem 2000 pound axles. The questions I have are; How do you determine the placing of the axle assemblies. (center of gravity stuff)? By eye balling several ready made trailers, it appears that the single axle is placed 2/3 back from the front edge of the bed. Is this correct? What about the tandem placement?
        sigpic
        Cantankerous Coot Enterprises
        Robert K. Tompsett CEO,CFO,CWM
        Lincoln 225 AC Stick Buzz Box
        Victor Portable gas welder
        Milwaukee Deep Cut Portable Band Saw
        Milwaukee Sawzall
        2 - Drill Presses
          Axle Placement
          I would think placement would depend on how you were going to load it, you want to avoid excess tounge weight, yet you need some to keep the trailer from going squirrely on you(for ball hitches). if your not sure how your going to load up the bed, try to split the deck length with the center of your axle(s)... on a different note make sure to keep your tounge length approx. 60% of the width of the tow vehicle, so when you turn tight you don't hit
          Good Luck!!
          Kelly
          Kelly
          Trailblazer 301D
          2 XMT 304's
          Dynasty 300 Tigrunner
          Spectrum 2050
          XR with ALUMA-PRO
          12RC suitcase
          Millermatic 251
          60a feeder
          Ellis 1600
          Bridgeport
          16" southbend
          Too many Hand tools...
            nfinch86- Canadian Weldor :
            YEA, I Bought Prints from Northern Tool, Great Prints TOO !!! ..... Norm :
            sigpic
            - Arcair- K 4000 CAC.
            - LN-25 Wire Feeder
            - Lincoln Power Mig 180C
            - Spoolgun.
            - DeWalt Chop Saw .
              Good Luck!!
              Kelly
              Thanks Kelly,
              This is the type of info I need!
              Will the 2x4 Box be strong enough for the structure? I am planning using the 2.4 box to both support the deck and be the structural frame rather than the traditional frame under deck design. I'll try and draw up my idea to post for critique.
              Hypertherm 380
                2x4 s plenty big enough but if its 16ga. then H**** no! imop it should be at least .120 wall 0r thicker depending what you hall. if your hauling, for example, a skidstear day in and day out then you should probably upsize to 3/16.
                just my 2 cents
                Miller Digital Elite inferno
                Miller MP-10 passive helmet
                Hobart Stickmate 250/160 ac/dc
                  I was planning on .120 wall and no way is a skid loader going on this trailer! I have a Jeep project that will be under 3000lbs. that will hauled on it. Then just odds and ends, 2x4s, hardwood, sheeting, whatever. Maybe motorcycles but never more than the 7000lbs. that the axles will handle (including the trailer itself). So, it would need to be able to safely handle 7000 lbs. plus a safety margin. I don't want some flexy trailer either, needs to stay flat and ridgid.
                  Hypertherm 380
                    Here's some info for you -
                    http://www.championtrailers.com/UTIL...AILER_KITS.HTM
                    You definitely want to price out what you intend to build vs. what you can
                    buy. Lots of people selling stuff off these days.
                    Check Ebay and Craigslist.
                      Hey Bob,
                      I have a small shop down in Florida and I was wondering how I could get into the trailer business. Who would I sell them to besides building one and putting it for sale on the side of the road. I've repaired more of them than I care to remember and have built three for shops that I worked at in the past. One was a huge BBQ grill, one a utility, and one a fifth wheel for a semi. None came back, so that was a good sign of axle placement and tongue weight. Anyway, do you have any suggestions?
                      Mike
                      www.blueblaze-usa.com
                      Live'n Life, Love'n the Ol Lady, Burn'en-Rods 813
                        Web Site !!!
                        Trep813,Mike, Hi; Congrats on the Web Site !!
                        Very Professional, Great Job !!!
                        .......... Norm :
                        sigpic
                        - LN-25 Wire Feeder
                        - Spoolgun.
                        - DeWalt Chop Saw .
                          i just bought 3 trailer plans from northerntools
                          18ft car trailer 16ft landscaping trailer and car dolly
                          plans there great
                            .......... Norm :
                            Norm,
                            Thanks about the wesite. I checked yours out, nice and clean. It looks good.
                            Mike
