Titanium Welding
  • Titanium Welding
    I was wondering if anyone on here has welded Titanium. I was searching the web and reading thru some books I have, it seems to get mixed reviews. Some say it can be done in an open atmosphere with proper shielding, back purge and trailing cup, others say it can only be done in a vacuum chamber or similar where the oxygen can be displaced.
    Where can I find a trailing cup? or is that something that has to be made myself? Whats your thoughts on using a sandblaster cabinet for a closed chamber?
    If you have welded titanium I would appreciate some feedback along with information regarding materials used and machine/machine settings, if it was done in open or closed atmosphere. And how is the weld pool/flow compared to steel and stainless steel?
    Hmmm that does it for now, thanks!
    nfinch86- CANADIAN WELDOR :
    eyecandy; HI , sorry man thats way above my pay grade!!!!.... Norm :
      You can weld Ti in a open enviroment . You must have good purge with a large gas lense and preferably a trailing rig . You can buy trailing rigs but for the money I'd make my own , they aren't very complicated . As far as settings you should give a idea as far as what you are welding . There is a local bicycle manufacturer that builds Ti bike frames and they use pretty low amps but it is very thin wall tubing .
      Dynasty 200DX "Blue Lightning"
      Bernard 3500ss water-cooler
      Rockwell vertical mill
      Beverly Shear B-3
      Beverly Shear JR
      Home-made English wheel
      Milwaukee Porta-band
      " Sawz-all
      Tennsmith 36" stomp shear
      Fixer upper 1968 Redface Lincoln sa200
      Powcon 300st
        Welding titanium
        Hi eyecandy,
        Here are 2 links.
        First one id here at Miller's site and is a great source of information.
        Titanium 101: Best GTA Welding Practices
        http://www.millerwelds.com/education...rticle120.html
        This one is a post I made May 22, 08 showing a 6-4 sculpture I made. Weighs 80 lbs.
        http://www.millerwelds.com/resources...ad.php?t=13065
        I have done a bit of tig welding of titanium but am not in any way an expert as the cost of the material and wire makes mistakes very expensive.
        I have found these steps help me when tigging titanium:
        1 - Use the lowest amperage setting you can for the material thickness. ti has lower thermal conductivity than stainless steel so it gets hot quickly.
        Too much heat will burn the welds.
        2 - Clean , clean and clean the metal. Grind, sand and use acetone on the pieces and wire. Clip the wire end before starting a new weld.
        3 - I use a long post-flow to try to keep the weld covered until it has cooled below 800 deg F.
        4 - Some say to use 2% lanthanated tungsten but I use 2% thoriated as this is what I have.
        5 - Use a stainless brush to brush the metal and dedicate this brush to titanium much as you would for aluminum.
        6 - A good weld will be shiny and have a silvery color. A purple, bluish, or golden color is signs of poor shilelding gas flow or short post-flow. I use 100% argon.
        good luck,
          I haven't had the opportunity to weld any titanium but from what I've read it looks like you have received some solid advice from some of the other guys with titanium experience.
          at home:
          2008 Suitcase 12RC
          Spoolmatic 30A
          WC-24
          2009 Dynasty 200DX
          2000 XMT 304
          Sold:MM130XP
          Sold:MM 251
          Sold:CST 280
          at work:
          Invision 350MP
          Dynasty 350
          Millermatic 350P
            I've welded titanium for several years for the aircraft industry, what burnthands and showdog say is correct. Cleanliness is very important. As is gas sheilding, titanium will react very badly to air. It will become embrittled and porous to the point that it is unusable.
            i've done vac chamber and "open air" welding with good results, just keep the argon there and stay out of drafty places.
            One other thing, it's kinda strange stuff in that it gets sticky when hot. The wire will fuse the the parent material near the weld zone so aim carefully or prepare to be frustrated.
            Just my .02 worth.
              titanium welding
              Hi Dave reynolds,
              Thanks for the great tidbit of information in your post.
              I too have noticed that my wire would tend to "stick" to the weld pool on occasion when tigging titanium and I figured it was something I was doing wrong. I have not had the same problem with stainless so I thought it was me. Thanks for the help.
              And to everyone, if you look at my welds, they may be pretty with the "rainbow" effect but strictly speaking they would fail the AWS standards.
              I make titanium sculptures but would never attempt to do any aircraft quality welds as this is way beyond my expertise.
              I do not have a weld chamber so I made a poor substitute out of plexiglas. Looks like a glass bead box or the baby incubators for premature babies.
              I have learned the hard way that argon is a lot cheaper that titanium.
              The more I learn, the more I strive to make my welds better and I'm sure this is why everyone is here also.
              thanks,
                quite right, argon is cheaper than titanium. Keepit clean and keep it covered with argon,the 2 cardinal rules.
                  Thanks for the replies!
                  I have been doing a bit of searching the last few days, I have found some decent information. I guess I could get more indepth of what I am planning on welding. I am looking to build a 3 or 4" exhaust, am possibly some other little mounts and braces. Right now I am having a hardtime finding the appropriate tubing, mandrel bends, mufflers etc for the exhaust, all the tubing is either smaller 2"or less or the wall thickness is around .028". I know typical steel/ss exhaust is .065" I am sure I can get away with a thinner way since Ti handles heat better, higher tensile strength, and better corrosion resistance. I think I have seen some Ti exhausts out there with .045" built by various tuning companies, but naturally I am not having luck finding those links again...
                  Mainly its beeing built for lightweight so a thinner wall, if it can be used, would help weight reduction. Any thoughts on this?
                  As far as the welding aspect, with it being tubing I will have internal purge, and buy or build a trailing rig, any ideas? I figure I sould be pretty good interms of the gas coverage, if there is an issue I figure it should be alright since its an exhaust and not subject to any kind of physical stress, rather some thermal and holding its own weight.
                  I know I have more to discuss, but I don;t want to bombard you guys with too much.
                    Your chances of finding titanium manrdrel bends in 3" or 4" are slim to none.
                    Especially in diameters that large, titanium is EXTREMELY hard to bend. That is why you see a lot of it with bends that are made from multiple pie cuts of straight tubing.
                    You can certainly use 18ga. You could likely use 20ga except for the downpipe which would still be worth using 18ga.
                    Since you generally need to do pie cuts for bends, making a Ti exhaust is a very expensive and time consuming operation.
                    I would make a 16ga stianless downpipe and then use 16 gauge aluminum if I really wanted a light exhaust. It's be lighter and cheaper and easier to make.
                    Durability is fine if you are careful about hanger placement and etc. Use stainless steel hanger that clamp around the aluminum. Aluminum hangers welded to the tube will break. Otherwise you're good.
                    I would guess aluminum would be roughly 1/10th the cost, 30% lighter, and 1/4 the work.
                      Thanks for the reply.
                      Is the gauge thickness the same on Ti as it would be on Steel, as I know Aluminum is slightly different.
                      Do you have any information on figuring out the pie cuts to build my on angles?
                        It's the same for gauge.
                        Try the fabricating forum at www.homemadeturbo.com - there is a sticky topic with info on pie cut bends there I think.
                          The actual Welding of Titanium is pretty easy. The puddle is easy to see and is very fluid. All the headaches come from the prep work and adherence to procedures. The "criticality of application" is a really big factor.
                          Some codes alloy only light straw discoloration while others allow blue and purple.
                          Welding inside a chamber automatically increases difficulty and takes longer but sometimes is necessary.
                          Whenever I have a choice , I use trailing shields, backup devices, and oversize cups to accomplish shielding. rather than opting for welding in a chamber.
                          Here are the worst things you can do in order of importance.
                          1. accidentally pick up the wrong rod....keep all other rods away from the work area unless you like hearing cracks form while you weld.
                          2. not shielding the back side of the weld with argon...this makes for a brittle weld...not as bad as using the wrong rod, but still junk
                          3. not cleaning the metal....porosity is usually the issue here.
                          Jody Collier http://www.weldingtipsandtricks.com/sigpic
                            I ride a Litespeed bike. The folks there have a lot of Ti welding experience. Their Ti tubes and rods have similar sources.
                            www.litespeed.com
                            Another outfit that is at the top of the heap in Ti welds is Moots.
                            www.moots.com
                            Miller Pro 300
                            Craftsman buzzbox
                              Titanium
                              I have welded Titanium ejectors *exaust pipes for the T-700 gas turbine engines on Helicopters*.
                              Open air environment as they are way too big to fit inside of a purge chamber.
                              A trailing cup is one thing I used *home made*
                              However on these units there are places that a trailing cup is just too big and cumbersome to work.
                              For those welds I found going slow and only welding about 3/8 to 1/2 inch at a time then letting the weld cool before continuing on worked out nicely.
                              As stated Use a large cup *I myself like the # 10* gas lens if you have one.
                              Use as low current as possible and still get adequate penetration. The welds on Titanium should never be allowed to turn ANY color, they should come out shiny almost like chrome. Too much gas flow can cause a real problem with Titanium if you draft air into the weld because of high gas flow the weld will be contaminated and become very brittle.
                              Backup gas is a MUST DO! Pre and post purge is a MUST DO!
                              I have even had to do some pretty long welds on these ejectors one spot at a time.*very time consuming* But then we are talking a very expensive Helo engine part and time is NOT of the essence.
                              Others have posted good info on Titanium here These are just a few of my techniques
                              Oh and dont forget .... cleanliness is next to Godliness and makes for good welds too.
                              Hope this is some help
                              P.S. one last thing, there are times when I have found a slight trailing angle of the torch is some help too, obviously not when using a trailing cup though. AND a trailing action on the torch has a tenancy to make it difficult to see what you are doing but a person must do what he must do to accomplish any given task.
