Balcony Railing Project
  • Balcony Railing Project
    I need to build a bunch of balcony railings for a property i'm a partner in. problem is, i have never built a balcony railing nore do i have an artistic bone in my body. i have looked online and found a lot of neat stuff, unfortunately i have to do them on the cheap, so the money i spend will go into simple but strong railings. The building is old, over 100 years, so i would like to make something that doesn't look to modern. Do any of you guys know where i can find design ideas? Right now i'm thinking just a top and bottom rail with square uprights (i said i wasn't very artistic!). What is a good spacing for the uprights? i see 4-5" in some drawings. What size/gauge should i be using? They will be around 6-8 feet long and anchor to columns or 6x6 posts. Should i put mounting plates to the decking? I will have to build them to size and truck them almost 400 miles so a mounting system that offers some adjustment would be great. Any input is appreciated!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    there is no "good" spacing only "Code" spacing
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      What he said. Handrails are a big deal in most places and the local building codes will stipulate the "requirements". You should start there before you do anything IMHO.
      Dynasty 350DX
      Dynasty 200DX TigRunner
      MM 350P
      MM Passport Plus
      Spectrum 375 Extreme
      08' Trailblazer 302
        Ed speaks the truth.
        If you really want to get technical, you should also find out about the required minimum height for the top of the railing. If you are doing any handrails, you need to be aware of not only the shape of the handrail, but also the height as it relates to any stairs, and finally the details of any returns. Quite often, the handrail need to return so as not to leave protrusions for clothing to catch on (in an emergency egress situation).
        It all depends on the code requirements in your area... and the inspector(s), if any.
        Keep the design simple and build it well. Building something with thought and care will often lend enough to the design in and of itself.
        Maxstar 200DX
        Maxstar 300DX
        Passport
        Spectrum 701
        LMSW-52 spot welder
          beyond meeting the code...
          check out king metals (http://www.kingmetals.com)
          or architectural iron designs (http://www.archirondesign.com)
          for ideas -- they have pretty extensive on line catalogs with
          lots of pictures.
          f
            Thank you all for your input, i will follow up with my partner who lives in the area. Then i'm sure i will have more questions. I will also try to find the pictures of the existing balcony railings. My biggest hurdle is that the property is almost 400 miles away, and i have a day job
            Dynasty 200 DX
            Millermatic 175
            Spectrum 375
              also keep in mind that there are sometimes a minimum horizontal load at a specificed height that it must withstand.
                a pic of the junk that needs replacing. I intended to make the new ones higher and anchor them better, those rickety columns aren't structural, and may be replaced with 6x6, not sure yet.
                Dynasty 200 DX
                Millermatic 175
                Spectrum 375
                  To my knowledge most local codes have adopted the ADA standards.
                  They the ADA standards are a good place to start any way.
                  Found at http://www.ada.gov/reg3a.html
                  Generally it must pass the 4" ball test must be 42" tall and withstand minimum force of 200lbs lateral force applied to the top edge.
                  Generally one must know a bunch of stuff to make a proper guard rail
                    railings and codes
                    The first place to go is the place you get a building permit from, i.e. the place with jurisdiction over what you will build (many local libraries have copies of codes for free inspection). Each municipality usually adopts the basic code as noted above, 4", etc. but some opt for more restrictive rules. To further muddy the water, there are places with NO codes, but then there is the National code.
                    Know the rules before you start. Do NOT assume anything or let anyone tell you that "x" is ok! Pay for a copy of that portion of the code applicable to your project and KEEP IT!
                    None of this really matters until someone gets hurt!
                    Artist Blacksmith
                    Historic Downtown
                    Paris, Texas
                    Dynasty 200dx
                    Trailblazer 302
                    12VS wire feeder
                    Lincoln 215
                    Miller Passport
                    Miller 375 plasma
                    Hossfeld bender
                    Antique SA200
                      Codes
                      What he says ond one thing more. If I have ANY question about a job that seems to deviate or conflict with code, I go directly to the building inspector for clarification. It may take a little more time, but there is no tearing out and re-doing later.
                        Thanks for all the advice. I will do my research before i do anything else. Unfortunately contract negotiations are going south so i won't be spending a penny until it gets sorted out.
                        Dynasty 200 DX
                        Millermatic 175
                        Spectrum 375
                          Here's a place to start for ideas...
                          http://www.artisticironworks.com/dbrail.html
                          FATFAB hit the nail on the head.
                          The International Building Code requires railings to be 36 or 42 inches high... 36 for residential (as in single family residence) and 42 for commercial. An apartment complex is generally considered commercial. It appears that the existing rails are only 36 though. Hard to tell because I'm judging scale from the guy at the bottom.
                          No opening should be wider than 4".
                          The fuzzy part is that the rails have to withstand a concentrated load of 200 lb applied. That's a pretty long span across those columns for slender tubing to withstand 200 lb applied at the middle without excessive deflection.
                          Whatever IBC says... Whatever NYC has adopted from it, the ultimate test is whether the building inspector likes it and likes you. Sometimes they don't even look at it. NYC Department of Buildings even says on their website:
                          "Difficulties in understanding the Code has led to confusion, inconsistency, delays, and added cost for construction within New York City.
                          Lack of clarity within the Code and the need for various types of review leads to increased corruption hazards."
                          They pretty much tell you to have cash ready when the inspector comes.
                            This might be too obvious but... search Google Images with a simple query of "balcony railings"
                            I got some nice pics at the link below since I recently considered a similar project:
                            http://images.google.com/images?gbv=...ilings&spell=1
                            MillerMatic 140 Auto-Set
                              Bodybagger-
                              I don't think the existing railings are 30" high! Luckily for me it's not in NYC. Actually it's close to canada. From what i understand, there aren't many codes or inspections that take place up there. I have no intentions of building anything shoddy or questionable. I take any safety related thing i do very seriously. I will likely build a test railing first and determine fit and strength based on that, the columns are likely to be replaced. Maybe with 6x6 or 4x4 with an outer decorative cover. Either way the attachemnet method will be robust and i can also screw feet into the decking for verticle loads.
                              Dynasty 200 DX
                              Millermatic 175
                              Spectrum 375
