Plasma screen stands
  • Plasma screen stands
    I've been procrastinating long enough and need to knock out eight freestanding supports for some plasma screens to go in some corporate place somewhere.
    Short story is they get a 3/8" thick x 32" diameter steel base, which also gets a 5" x 1/8" skirt. Two 3" OD tubes rise up about 60" and a 1/8" plate gets welded between them to which the factory bracket mounts, and then the screens will hang from that.
    Here's the start:
    1) Eight bases, the template, and the drop. Heavy metal.
    2) Eight mounting plates waiting to bridge the gap.
    3) The bases get bolted to the ground, but they still need to be levelled, so I'm making three adjustable pads for each base, which will get welded to the underside of the disks and be concealed by the skirt. Parts is parts.
    4) My super fancy jig.
    5) Zing-bang.
    Thanks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Sweet!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
      What does the finished product look like?
        I don't know yet... . Check back in a couple of weeks.
        Once completed, they will get an automotive paint finish.
        Maxstar 200DX
        Maxstar 300DX
        Passport
        Spectrum 701
        LMSW-52 spot welder
          Hey Nice work!!
          That stuff looks great! I only wish I had the refined tecnique you show here!
          I have a Dyn200dx and I love it! I assume that is what you accomplised these weld with!?
          Again,,,good work!!
          MB
            Again,,,good work!!
            MB
            Thanks for the kind words.
            Actually, I used my Passport to weld up those adjustable feet. Quick and easy.
            It's all in the planning, really. Not much to the welding. You'd be surprised.
            Maxstar 200DX
            Maxstar 300DX
            Passport
            Spectrum 701
            LMSW-52 spot welder
              progress
              Here are some progress pictures.
              The skirt/rings are rolled from 1/8" x 5" material. I have to roll them in two halves. Therefore, the halves must be left long, then trimmed to size to fit the base.
              Question: How do you trim the flats off of the rolled halves?
              Answer: I have a shop full of bandsaws, but I'm using a vintage hand shear I picked up for $80.
              The shear rolls the ends a bit (as shears do), so we have to flatten them out with an expensive flattening machine.
              1) Rolled halves. These were rolled on my home-made roller (see other post).
              2) Jigged.
              3) Fancy, expensive cutting tool.
              4) Expensive, complicated flattening machine
              5) Detail of underside.
              Thanks for looking.
              Maxstar 200DX
              Maxstar 300DX
              Passport
              Spectrum 701
              LMSW-52 spot welder
                base
                Picture of the base. There will be eight of these.
                Maxstar 200DX
                Maxstar 300DX
                Passport
                Spectrum 701
                LMSW-52 spot welder
                  If your shear is rolling the edge then the blades are not sharpened or not adjusted correctly. There should be no rolled edge on a sheared plate.
                  MM250
                  RCCS-14
                    I should clarify. The blades make a clean cut. I wrote that it rolled the edge, which is misleading. The cut is clean, but the plate distorts/curls over the 5" width. This hand shear has a 4" blade, so I have to take the cut in two bites.
                    Every shear I've ever used distorts the metal to some degree. Every piece of metal I've had sheared by someone else has been distorted to some degree. This applies to manual, electric, hydraulic, whatever. Every piece of paper I've cut with a pair of scissors has a curl to it.
                    When I need to cut something with no distortion, I use a saw... or a water jet.
                    On a similar note, I use a drill press (or water jet) to cut holes rather than a punch, which distorts the metal.
                    Thanks for looking.
                    Maxstar 200DX
                    Maxstar 300DX
                    Passport
                    Spectrum 701
                    LMSW-52 spot welder
                      Chris*** - Just a question. Why do you have to roll the rings in halves?
                      Thanks.
                        With pretty much any 3 point roller you end up with a flat on the beginning and end of the raw stock which accounts for the distance between the center and outside roll. You can roll the ring to compensate for the excess, or you can roll it to diameter and half it like Chris does.
                        If you don't mind 2 seams, Chris's way is faster and easier. Especially with thicker material, you end up fighting it when you reach diameter with the excess for the ends.
                        Syncrowave 250DX
                        Invison 354MP
                        XR Control and 30A
                        Airco MED20 feeder
                        Thermal Dynamics Cutmaster 81
                        Smith O/A rig
                          You can roll some stock with one seam, like the wheel I made from 1" round tube for my roller. Stock like this has enough spring to it that you can pull it to the side of the machine to complete the circle.
                          Like Jim said, 5" flat bar doesn't have a lot of give, so I did it in halves.
                          I was originally going to have another fabricator (who has MUCH more experience than I do) roll these up for me. We talked about it and he said he would probably do it in halves for the same reasons. He also mentioned that the end result would have a truer radius. With more projects lining up, I decided to make my own roller, but I still took his advice and did it in halves.
                          I'm not sure if I could have done it in one piece. It's too late to find out for this job.
                          Maxstar 200DX
                          Maxstar 300DX
                          Passport
                          Spectrum 701
                          LMSW-52 spot welder
                            You have to have the stock cut to length which includes the "Flats" at each end.
                            Example: 6" Ring
                            Circumference = 18.84
                            then add however much material is taken up by the Flat at each end by the type of roller you are using.
                            So if it is 2" then the stock is cut to 22.84"
                            Place the stock in the roller like in the Photo, apply a little pressure, roll through one way till you reach the "Flat", apply pressure, roll it back.
                            Repeat until you have the ring size. Towards the end you'll have to nudge the ends so the flats over lap until the "Flats" match up. remove and cut the flats off.
                            Ed Conley
                            MM252
                            MM211
                            Passport Plus w/Spool Gun
                            TA185
                            Miller 125c Plasma 120v
                            O/A set
                            SO 2020 Bender
                            You can call me Bacchus
                              Example: 6" Ring
                              Good explanation.
                              Now someone show me a picture with some 5" x 1/8" (or equivalent) material.
                              Maxstar 200DX
                              Maxstar 300DX
                              Passport
                              Spectrum 701
                              LMSW-52 spot welder
