Flying Project
  • monte55
    started a topic Flying Project
    Flying Project
    I saw this a while back and became very interested in it. It has counter rotating blades so no tail rotor is needed to compensate for torque.
    I am in communication with a gent in Belgium who is building a "backpack" helicopter. I'm trying to gather as much info as I can before starting construction. There are no plans.....just pictures. I had a Scorpion 1 heli back in the 80's. Repaired it but never flew it. This as you see is simple, it works, and no license is needed to fly.
    http://www.youtube.com/watch?v=f09_yvcASLM
    http://www.youtube.com/watch?v=Vp0WnZ-4Tqg
  • H80N
    Originally posted by monte55 View Post
    When you say mast, what are you referring to?...The 2" square mast as I call it or the 1" rotor shaft. No calcs were done. Just looked at a lot of other projects and came up with this.
    Monte
    was referring to the "Rotor Mast"
    You may find it useful to refer to Wayne Johnson's text "Helicopter Theory" it is pretty much the standard reference in rotary wing design...
    "Monumental text offers comprehensive, detailed coverage of every aspect of theory and design: elements of vertical flight, forward flight, performance, mathematics of rotating systems, rotary wing dynamics and aerodynamics, aeroelasticity, stability and control, more. Essential reading for those interested in design and development of vertical-flight aircraft. 189 illustrations. 1089 pages
    1980 edition."
    http://books.google.com/books?id=SgZheyNeXJIC
    there are lots of used copies available at reasonable prices...
  • monte55
  • H80N
    OK.... that spider gear setup is a simple elegant solution... Thanks!!
    The mast does look a little lightweight.... know the loading is way different.. but the ones on the Bell Jetrangers and Hughes 500's that I am used to are massive by comparison..... how did you calculate the loading on it??
  • monte55
    http://youtu.be/MHQ4k3dKqtg
  • H80N
    Contra Rotating Propellers
    Been seeing more and more contra rotating propellers in the radio controlled world and was wondering how your full sized project was coming along.... was also wondering if you might share some pics of the gearbox scheme you used to achieve the contra rotation...
  • Bert
    Just wanted to reiiterate (sp?) on what I told you before and what others have said: BE CAREFUL!!! We'd hate to lose you........
  • monte55
    Originally posted by kiwi View Post
    Nick,
    Thanks for the videos, they are great. So what is the next test? Did you notice much lift during your test? How much throttle did you use? Keep it up and good luck.
    Nick
    The rotors are at 0 degree pitch now so no lifting. I am in the process of making 8 degree wedge shims to give the rotors positive pitch. It's a starting point and I'll see what happens. Btw...so far throttle has been on the low side.
    Nick
  • Goodhand
    Originally posted by MrBill View Post
    One of the biggest issues I see is it will not be instinctive to fly with the control system that you are using. Push left to go right, pull back to go forward.
    Pretty much the same as flying a hang glider. Or, guiding an auto by grasping the steering wheel below center.
    It's intuitive, once you're airborne.
  • MrBill
    A very ambitious project. Be careful.
  • Rick C
    Nick,
    Can I put a life insurance policy on you? It might pay well with that contraption!!!!
    One thing I would do is put a shield on the drive shaft if I was you. You have a lot of trust in your work.
    Rick C.
  • kiwi
    Nick,
    Nick
  • Matt_in_Brooklyn
    Wow
    I will echo earlier comments and say that is one of the craziest things I've seen on this board. I see you wear a lot of different hats, I didn't think Test Pilot was one of them. Please stay safe.
    Matt.
  • monte55
    New videos on Monte's heli project
    Well now that the weather is warming up some I thought it's time to do more
    testing with the heli project. I uploaded 2 new videos of running up the engine
    and drive train with all 4 rotors installed. I still have a lot to figure out. This is for the ones that requested updates on my progress.
    Nick
    http://www.youtube.com/watch?v=SoPOlKnJFwA
    http://www.youtube.com/watch?v=-df8RKaa_h8
  • m.k.swelding
    now I thougth I had seen it all.
