Flying Project
  • Flying Project
    I saw this a while back and became very interested in it. It has counter rotating blades so no tail rotor is needed to compensate for torque.
    I am in communication with a gent in Belgium who is building a "backpack" helicopter. I'm trying to gather as much info as I can before starting construction. There are no plans.....just pictures. I had a Scorpion 1 heli back in the 80's. Repaired it but never flew it. This as you see is simple, it works, and no license is needed to fly.
    http://www.youtube.com/watch?v=f09_yvcASLM
    http://www.youtube.com/watch?v=Vp0WnZ-4Tqg
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Hey Nick,
    It looks like a fun project. Will this type of "helicopter" autorotate in the event of engine failure?
    Nick
      No.........the rotor does not have enough mass and the rotor is fixed pitch.
      To autorotate in a helicopter which is normally operating with a positive pitch
      per the collective control....when loss of power happens the pilot will go negative pitch to keep rotor RPM up like an autogyro and when at the proper
      altitude and start a flair pull positive pitch per the collective control and settle to the surface. You have one chance to do this and do it correct. I relate it to holding a stick shift automobile heading uphill and letting it roll back and when it starts to roll back letting out the clutch to hold it there if that makes any sense. I would never fly this out of ground effect (approx 5-8feet) unless over water or it proved to be extremely reliable. You really gain nothing by flying this higher than to clear ground obstacles. I'm ok with that. Drive thru at the bank could be a problem
      One of the videos shows this flying about 15-20 feet off the ground. I would not want to fall that far if there was a problem. But Man.........how cool would this be?????
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      2-O/A outfits
      Jet Lathe and Mill
      Propane Forge
        Without a doubt it would be fun. The other concern I would have is that the rotor appeared to be close to the pilot's head with no safety device. To me this is also a worry. Where did you get your helicopter knowledge...you seem to be well versed in the physics and mechanics of helicopter flight.
        Nick
          i would think the one used in the james bond flick with the little cabin and one big rotter that flew more like a plane then a hello would be an easier build. i suspect you would need a license and inspection to fly it though. however it dose auto rotate to allow for safe landing should it's motor die in use. the back pack fan with a para-shoot thing is also cool and again more on the safe side should the motor take a dump.
          wonder what the build $$$ would be for the lil james bond version ???
          be shore to keep us posted on your build.
          sigpic
            Nick
            The rotor being close is no real problem unless you feel the urge to raise your arm to wave at someone
            If a rotor broke loose it would be inclined to go up and out. The out of balance issue would be the real problem.
            My knowledge of helis..................well, .....early 70's I purchased a set of plans for a homebuilt helicopter called a Choppy powered by a 650 cc Triumph
            motorcycle engine. I think I still have the plans somewhere. I realized quickly
            I didn't have enough knowledge, tools, time, etc to do this project properly.
            The idea though has never left my mind. So, I built a hovercraft in mid to late
            70's. Engines and propellers seemed to feed my yearn for a short while. The hovercraft is on this forum somewhere. Ok sold it. Early 80's.............found a Scorpion 1 single place homebuilt heli in need of repair cheap. Paid $600...
            put in a few hundred more and many hours of labor and had everything going
            except it needed a main rotor. I sold it that way and made enough profit to purchase by my Cessna 150 a month later for cash which I aquired my pilots license in. During the heli stage I did a lot of reading etc. I had many manuals on the Scorpion and learned a lot. Those guys are gone now but not the dream. So another project is in order. yeaaaaaaaaaaaaahhhhhhh!!!!!
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            2-O/A outfits
            Jet Lathe and Mill
            Propane Forge
              Bond flew an autogyro. The main rotor is not powered and act like a wing for
              lift as it rotates with forward air speed supplied by the engine and prop behind the pilot. If they loose the pusher engine, they can still land safely
              if they have been taught properly and glide in. Gliders do it every day.
              There is a 1969 Bensen autogyro on e bay for about $2200 with no bids.
              Oh yeah..................Bond had missles and stuff.........cool!!!!!! Ya know these add to the cost
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
                My knowledge of helis..................well, .....early 70's I purchaced a set of plans for a homebuilt helicopter called a Choppy powered by a 650 cc Triumph
                except it needed a main rotor. I sold it that way and made enough profit to purchace by my Cessna 150 a month later for cash which I aquired my pilots license in. During the heli stage I did a lot of reading etc. I had many manuals on the Scorpion and learned a lot. Those guys are gone now but not the dream. So another project is in order. yeaaaaaaaaaaaaahhhhhhh!!!!!
                Hey Nick,
                The same for me I had a private pilots license and enjoyed flying. I flew a Skipper and a 152...then I had kids and could not justify my hobby. As far as the gyros go I have flown in a two place gyro...there were two popular brands at the time, his was a Benson. I believe they were Benson and Air Command does that sound correct? I will tell you that flight was ten times more exciting than my fixed wing flights. Basically you have a seat (which doubled as a fuel tank) under your butt and a stick of aluminum between your legs. These were Rotax, Subaru or VW powered. Keep me posted if you decide on the gyro.
                Nick
                  whats that have to do with welding this site is going to s--t
                  is so slow
                    is so slow
                    what are you trying to say?
                    Nick
                    Miller 252 Mig
                    Miller Cricket XL
                    Millermatic 150 Mig
                    2-O/A outfits
                    Jet Lathe and Mill
                    Propane Forge
                      Wait wait, let me guess i think i know where this is going.......
                      Would those plans require any "Welding"???
                      Monte, i think its great. I have always wanted to build a homebuilt airplane. I got my start in aviation (i got my A&P at 18). Unfortunately life takes in different directions than we may want. I will be watching, post plenty of pics
                      Dynasty 200 DX
                      Millermatic 175
                      Spectrum 375
                      All kinds of Smith OA gear
                        If it were an airplane then Monte could build it with the Diversion.
                        Tim Beeker,
                        T-N-J Industries
                        (my side bussiness)
                        Esab 450i with wire feeder
                        HH135 mig
                        Miller aircrafter 330 - sold
                        Marathon 315mm coldsaw
                        table saw
                        Dewalt cut off saw
                        Sand blast cabinet
                        lots of hand grinders
                        Harris torch
                        beer fridge
                          I think ill wait till the Harbor Freight model comes out.
                          2- XMT's 350 cc/cv
                          1- Blue star 185
                          1- BOBCAT 250
                          1- TRAILBLAZER 302
                          1- MILLER DVI
                          2- PASSPORT PLUS
                          1- DYNASTY 200 DX
                          1- DYNASTY 280 DX
                          1- MAXSTAR 150 STL
                          1- HF-251 BOX
                          1- S-74D
                          1- S-75DXA
                          2- 12-RC SUITCASES
                          1- 8-VS SUITCASE
                          2- 30 A SPOOLGUNS
                            Hmmmmm.
                            It looks like it might be fun. I can see the connection to welding effort also.
                            I must say, however, that it looks like the operator (pilot?) would be in a very precarious position in the event of a crash. Those two blades would filet the pilot in the time it would take to stop once it hits the ground.
                            I guess I'm saying that it looks extremely dangerous due to the open blades.
                            Milermatic 252
                            Lincoln AC/DC "Tombstone"
                              Yep....looks about like a hand held brush hog....that flies!!!!!!!!!
                              so...what seems to be the problem???
                              Miller 30-A Spoolgun
                              Miller WC-115-A
                              Miller Spectrum 300
