Corner Post - best practice
  • Corner Post - best practice
    Here's my problem:
    In making corner posts for barbed wire fence I am using 4x9 steel posts spaced 8 foot. I need to set a diagonal 2" post for support between the two. It's always a 'hit and miss' on getting the right cope and angle between the two sizes and have wasted way too much pipe. How would the pros do this job? I've tried just using the good 'ol H configuration but it doesn't always hold up to tensioning. Certainly there has to be some sort of template one could use to get the copes right. If so any source ideas?
    Your help is greatly appreciated.
    welcome to the site. lots of great people here with lots to share.
    the easyest methode would be lay the pipe in place and scribe it.
    math would be another way, a string and one of those ajustable angel guides would be another..
    perfect is not needed but close like within a few degrees, shold be good enough for the weld to cover.
    sorry i cant give you a pro priceing but i would suspect matereals +30% and time at your going rate.
    are you using stick or MIG to atach them ??
      pipe templates
      The easiest and fastest and cheapest(wasting pipe) way i do is save the cartoons from your sodawater or other beverage packs, cut it out to a square and roll it up to the size of pipe you are working with, tape or staple together and start cutting til you get your fit then transfer to pipe. works great for me ,and do not waste material .
      /22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
      33x33 enclosed shop when its to cold or windy outside
      miller 210
      miller 875 plasma
      victor oxy/accet
      unihydro 45ton ironworker
      miller 180 tig
      ole lincoln ac/dc buzzbox
      milwaukee power tools
      and everything in between
      2007 trailblazer 302
      Bailiegh 210 miter saw-2008
      Beer Fridge
      6000# cat forklift
      36" port-a-cool fan
      Dake G-75 Belt grinder
      3035 Spoolgun
        Each person has their own bracing method. Here's what mine has evolved to.
        I use two vertical posts 7'6" apart and a short post another 6' out. I install a horizontal rail between the two full height posts so that the top of the horizontal is 46" off the ground. This insures the brace won't be in the way of tying 4"x48" netting wire.
        The short post is installed 6' out at 1' off the ground and a diagonal brace is welding on top of it with the other end butt welded to the full height post at 46" off the ground. This way, it matches up with the horizontal bracing. At a 6' spacing, a 7'6" diagonal pipe hanges off the short postby 6" to 12".
        All the cuts are 90 degree saddle cuts with the exception of one end of the diagonal brace and the top of the short post. If you do the math, you will find that both these two non-90 degree saddle cuts are at the same angle. It's something like 26 degrees. The triangle it makes is is 6' by 3'.
        I use a ShurKut jig for the 90 degree saddle cuts and a home-made jig for the 26 degree cuts. This jig is home made and consists of two items. The first is the jig itself. I cut in on a mill using a 2 3/8" hole saw set at 26 degrees. It slides over the 2 3/8" pipe and I guide my torch around it and clean it up with an angle grinder. The second part is a "test fit jig". It's basically a piece of flat stock cut to 26 degrees and welded to a 6" piece of 2 3/8" pipe. I can lay this jig against my angled cut and check the fit, clean it up with the grinder, check the fit again, etc.
        This allows me to make accurate angle saddle cuts fairly quickly. If the ground isn't level, I've found I can vary up to about 15 degrees and still make a decent fit.
        Millermatic 35
        Miller TB302G
        Ellis 1800
        Smith & Victor Torches
        Optrel Satellite
        Arcair K4000
        Ingersoll-Rand 175CFM Diesel Air Compressor
        Home Made Welding Trailer
          Some great information here, thanks.
          On the saddle cuts you mention the ShurKut jig but I can't find any information on this. Do you know who makes it?
            There's a little black book called the Pipe Welder's Handbook you can get for about 20 bucks or less and it has allkinds of cool formulas that are easy to understand. It's about the size of a 4x6 card. I'm sure you could find it on amazon or Otherwise, try making a template out of manilla folders. I've got a little farm in Texas and I feel your pain....literally.
            Matt Adams A&P, IA
            Trailblazer 302
            Dialarc HF
              There is free sofeware called 'tube miter' you can download off the net, it works in metric, but is easily converted to inches. The software will give you the templates (printed) for joints of any configuration up to 3.5 inches. I use it all the time, and it is worth looking into.
              Dynasty 300DX
              Esab PCM 1000
                I stumbled on a really good program in another forum for coping pipe which may be the one you were referring to. In any case the first link is for online viewing and the second link is the executable program for download.
                Check it out...
                  Here is the link to the Shur-Kut jig. You can find them at good welding supply stores.
                  Millermatic 35
                  Miller TB302G
                  Ellis 1800
                  Optrel Satellite
                  Arcair K4000
