Lets see some beads
  • Lets see some beads
    We havent had any beads around here in a while. I'd love to see some decent Stainless welds- seeing as how thats where my troubles have been lately. Anyone care to share?
    Ive pasted 4 pics. Four different levels of competance. 4 pics, 4 minutes of experience....
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    way too hot, turn down the amps. im guessing ur tigging these welds? amps at about 50 for this light of stuff and make sure u have good gas flow. ill try to get into the shop do do some for ya and take some pics but been pretty busy packing. (moving to australia)
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
      hey were are u at in van? i have to spend a couple days in surrey before i go ill be there right around the 7th of july pm me if ur close and want some help.
      trail blazer 302
      hypertherm plasma
      millermatic 251
      o/a torches
        Stainless welds
        Here are a couple I have done. Nature of the business-I can't load more it would give the project away.
          more
          more stainless, I had to crop some of the project out and resize so it made some pics a little fuzzy. These are from a "canned" accu-curve program in the Axcess machine.
            here's a couple of some welds done using an Argon/Hydrogen blend. the hydrogen produces a reducing atmosphere that helps reduce the oxidation to pretty much zero. increases fluidity, faster travel speed, lower heat affected zone, etc.
              Here are a couple of my practice beads, I have only a been tig welding for about a month. The stainless is some 1/8 scrap with 308L filler I got from a machine shop and the aluminum is some 1/16 6061 with 5356 filler. The T-Fillet weld looks slightly "Sandy" but it is because of the weld I ran on the backside.
              -Dan
              Owner
              DW Metalworks LLC
              Miller Trailblazer 302
              Miller 8RC Feeder
              Miller Passport Plus
              Miller Dynasty 200 DX W/Coolmate 1
              Hobart Handler 135
              Hypertherm PowerMAX 30
              Smith O/A Torch Set
              Plus more tools then my wife will ever know about....
                TIG welds
                Aluminum is a blast isn't it. Your welds are looking good. It has always amazed me how 1/2 way through a weld you have to back off a little or the puddle gets to large. I know it is the heat and I understand the thermal dynamics of the weld. It's just so cool, welding a awesome!
                  Not a bead, but some stainless on pipe....with O2 tank partially full, every thing turned out a ok.....Paul
                  More Spark Today Pleasesigpic
                    your bead
                    You are using a spool gun, not tig, right?
                    Millermatic 210
                    Syncrowave 200
                    Spectrum 625 X-treme
                    Hobart Champion 16 W/
                    Miller 8VS Suitcase
                    Miller 3035 Spool Gun
                    Tons of Tools
                    Microwave
                    Laptop and Printer
                    Speakers in the Back for all to hear Sirius Radio!
                      Your Beads
                      Very nice work!!!!!
                      Millermatic 210
                      Syncrowave 200
                      Miller 8VS Suitcase
                      Tons of Tools
                      Microwave
                      Laptop and Printer
                        You!!
                        You do some weird stuff!! Where do you live?
                        Millermatic 210
                        Syncrowave 200
                        Miller 8VS Suitcase
                        Tons of Tools
                        Microwave
                        Laptop and Printer
                          I just dont get get it
                          Hey Guys,
                          Dem's some nice lookin weld fer sure... I dropped the heat, upped the gas, moved a.f.a.p. and still get blackbeards remains err I mean blackbeads just the same...
                          I guess I must practice more. Whats the key to those nice rainbow looking beads?
                          nice going guys.. kudos to all!
                          Syncro200
                          Spectrum 625
                          O/A
                          54" laminator
                          little dog
                            Good gas coverage and not too much heat for the rainbow effect, but a good weld should probably not even be discolored...IMO, Paul
