Big Tig welding
  • Big Tig welding
    Thought I would share the work I picked up this week as it is a little out of the ordinary for me. I have done this kind of work but it usually only comes up maybe a half a dozen times a year. The pics are of pieces that are related to the aviation work I do. They are a mix of thick steel and aluminum parts and call for 1/4" fillets and/or V-groove fills.
    The first pic is of an assembly after final welding. It is clamped to a small surface plate while it is cooling. It was clamped this way for the initial welding, and then clamped again to cool after heating the backside (in order to minimize warpage). The second pic is a weld close-up of that same part. The third pic is of two separate assemblies that hold, and support, a larger axle assembly for an engine transmission. They have the first pass completed and are cooling in preparation for the final pass.
    The last two pics are of the aluminum assemblies. In the first one, the part on the left is set up to show what it will look like after welding. The pieces to the right are the same thing only a mirror image. The last pic is an assembly that gets 4 equally spaced two inch fillets on the top and bottom. All this is being done to print spec. using my 300DX and my Precision Tig 275. Thanks for looking
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
    Kevin,
    Great work as usual, I sure am lusting after those clamps
    Regards, George
      Great job, always a please to see your work.
      Laurence
      TO MUCH BLUE TO LIST
        dude r u a bmxer ? i see the S & M sticker on the welding helmet
          very nice
            Ok, a few more pics. The first is of the steel assemblies after the final pass. Again, 1/4" fillets are all that were called for here. The second is a close-up of the large circular assembly. There are 6 equally spaced fillets around the top and bottom, this is one of the top fillets. The next pic is a close-up of the welds on one of the aluminum block assemblies from the previous picture #4. Thanks for looking and for all the kind words.
            Dynasty 350DX
            MM 350P
            MM Passport Plus
            08' Trailblazer 302
              I wish i could weld as good as you! .. dam i'm jelous .. i got the same question ,, do you Bmx ? i also see the S&M sticker.
              Jorgensen MFG.
              Custom trailers:from utility to semi trailers i make em all.
              argonweld_bjorn@hotmail.com
              www.ehhitch.com
                I could help with refreshments in the background.If you take to machining like you weld there will be no work for the rest of us. Nice as always ,& keep the project pics coming.
                252 Miller Mig
                180 Synchrowave
                R - 45 Milling Machine
                Kingston 1100 Lathe
                Miller 2050 Plasma Cutter
                  Beautiful welds as usual. Could you please tell us where you got thoseclamps.
                  Wheelchair
                    i dont know where KB got em but i know you can get em at Air Liquide... they are like 80$$ each!! Ausome clamps tho
                    Jorgensen MFG.
                    www.ehhitch.com
                      If I remember right he got them at his LWS, on sale no less ... He could fall in a hog pen and come out smelling like a rose I think.
                      Regards, George
                        clamps
                        Wheelchair
                        I believe those are bessey brand clamps and the ones I have open 12" i think and were about 130 bucks a piece but they are awesome as long as you buy besset brand. Jef
                          WOW, This thread got resurrected from the bowels. Thanks Bro! At 42, I am a little old for BMX'in but I used to weld bikes for a living. Got those stickers at Interbike in Vegas one year.
                          Wheelchair
                          Thank you. Those clamps are Wilton clones of the Bessey's. Quite spendy but I did get my first two for a song. Couldn't live without them now.
                          Dynasty 350DX
                          MM 350P
                          MM Passport Plus
                          08' Trailblazer 302
