drier for air compressor
  • drier for air compressor
    who makes a good drier for my air compressor? I have a Motorgard filter on the plasma but need something on the compressor itself that has a dissecant in it.
    thanks
    littleboss
    porter cable makes a good drier / lubricator or just a drier the same with cambell/hossfield
      I use this one: http://www.pricegrabber.com/search_g...sterid=5432441
      Some other good ones here: http://www.airdryers.com/prod.htm
        If you have a truck junkyard in your area you can put a truck air dryer on it . They are made for lots of air volume and have dessicent cartriges in them.
          Thanks.
          I found a Campbell Hasfield at Amazon.com
            Water fights
            Boy do we need an air drier at work. If the compressor has been running for a few minutes and no a lot of air is being used you can take an air blower and shoot a stream of water clear across the shop! We even showed our foreman the other day.
              just a thought, i run a basic velocity change drier with a filter element for general use and then have a refrigerant based drier for the more critical processes that I turn on when needed. I couldn't complain, gave $20 for the drier at an auction and all it needed was a new power cord.
              SSS
                thats a sign to drain the tank.
