Miller212, 3035 Spoolmate, Aluminum Question
  • Miller212, 3035 Spoolmate, Aluminum Question
    My question has to do with processing. I am not new to Aluminum welding. I have been tig welding Aluminum for several years off and on. I have recently started a side business and do some fabrication out of my garage at home and wanted the ability to weld Aluminum with a minimum investment and most flexibility for the buck, so I went with the spoolmate.
    My welds look pretty good. I have good penetration, the weld is holding good based on the destruct test I have done, and for a first time mig process they look pretty good. Except there is a tremendous amount of SPLATTER on both sides of the weld. I tried slowing down the wire speed and got burn back (went through about 3 tips fine tuning) tried gas and heat settings. Is this just a characteristic of alum mig process?
    For fun I make metal art stuff, and the pitting and slag on the side of the welds about 1/2" or looks bad. Any suggestion would be appreciated.
    Last edited by bullet280; 03-19-2008, 02:13 PM. Reason: I said slag, Meant splatter
    My suggestion would be to POST PICS!!! A picture says a thousand words...
    Lot of experts on aluminum here as you probably know, but it would be a HUGE asset to actually see it!
    Congrats on a nice machine
    I'm not late...
    I'm just on Hawaiian Time
      You need to give a lot more information before the board can be of help.
      Gas, wire, amps, WFS, etc.
      I seriously doubt that what you're seeing is SLAG (unless you're using flux core)
      Syncrowave 250 DX Tigrunner
      Dynasty 200 DX
      Miller MM 251 w/Q300 & 30A SG
      Hobart HH187
      Dialarc 250 AC/DC
      Hypertherm PM 600 & 1250
      Wilton 7"x12" bandsaw
      More grinders than hands
        Sorry you are correct, I was thinking one thing and typing another I guess. I didn't mean to say slag (DUH!) I meant splatter.....
        I will try to get some pics tonight.... Thanks for the replies.
