Tig torches - is there a standard?
  • Tig torches - is there a standard?
    I was looking for some cups for my torch and I noticed that addd may say for example "for series, 9, 20, 25" torches.
    Is there some standard across manufacturers or manufacturer specific?
    Thanks,
    John
    Thunderbolt AC/DC
    MM 175
    Maxstar 150 STL
    Blue Star 185 DX
    Spectrum 375
    standardized
    mostly standard threw all makes. a #17 or 150amp torch will accept parts from most makers. the CK torches are interchangeable with weld craft and so on. its supposed to be standardized but it may be possible to get a really cheepo torch that wont play well with others.
    sigpic
      Tig consumables..
      The 17/18 torches and consumables are not compatible with the 9/20s. If you have a 17 (whether it is a Diamondback, Tweco, Weldcraft, etc) it uses 17/18 series parts. The same applies to the 9 series.
      HTH
      Triggerman
      Ammonia refrigeration tech
      Trailblazer 302 (yes, it's new)
      Millermatic 180 w/Autoset
      CST-250
      HF-15 High frequency
      XR15 w/Push-Pull Gun
      Victor O/A, DeWalt, North mask
      "A professional knows what to do. A craftsman knows why."
        Triggerman 150STL...
        Hey Triggerman...
        Thanks for your reply. I noticed the maxstar 150 stl listing on your signature. What kinda things do you use it for? Do you tig, stick weld both. I love mine; it is amazing for it's size and duel voltage. I have used it for some stick welding on job sites and now I'm learning to tig on it.
        Thanks,
        John
        Thunderbolt AC/DC
        MM 175
        Maxstar 150 STL
        Blue Star 185 DX
        Spectrum 375
          sorry i mis-understood your question. i thought you wanted to know if all similar torches like #17 from different makers would interchange parts.
          sigpic
            Greetings!
            I Tig and Stick with it. The 150 is the king of portability in my book. I even made a special cord adapter to grab 230V from two seperate 115V outlets on different phases in the breaker panel.
            I have tigged thin stainless in kitchens one day and stick welded 6" pipe the next day on live systems full of water.
            If I could only keep two of my blue boxes, they would be my Maxstar 150STL and my Spectrum 375-Xtreme plasma cutter.
            Good luck. HTH.
            James, don't worry about it. You gave an excellent answer to the question you thought he asked.
            Triggerman
            CST-250
              James...
              That really was the right answer in that I wanted to shop for some replacement parts for the torch and wanted to know what to look for.
              Of course I am so spastic at that point I was already on to my next question.
              Thanks again,
              John
              Thunderbolt AC/DC
              MM 175
              Maxstar 150 STL
              Blue Star 185 DX
              Spectrum 375
