Stupid question! Realy!
  • Stupid question! Realy!
    if I cleaned the metal befor using 6011 or 6013 would I get more penatration or would I have to use a diferent type of rod? just wondering
    Miller Digital Elite inferno
    Miller MP-10 passive helmet
    Hobart Stickmate 250/160 ac/dc
    6011 or 6013
    These two rods are in different leagues of penetration. 6011 has a lot. 6013 has a little.
    HTH
    Triggerman
    Ammonia refrigeration tech
    Trailblazer 302 (yes, it's new)
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Victor O/A, DeWalt, North mask
    "A professional knows what to do. A craftsman knows why."
      AC or DC, 6011 will run better with AC, 6013 with dc, and clean metal. What are you welding? BTW cleaner is always better.
        Ill probably be running ac. I was thinking of building a trailer. Maybe kind of like rbertalotto a few posts down from here. I want to get maxmum penitrarion because I'll be carrying my golf cart and didn't want it falling off>(it's my baybe)
          If you have a DC power source with sufficient kick, running 6011 DCEP will give you the most penetration. 6013 is a lower penetration rod designed for general purpose, lighter gauge work.
          No matter what rod, or what you are working on, it is always good practice to have you base metal as clean as possible.
          Makita 5" grinder
          Makita 14" abrasive saw
          IR SS5L compressor
          and a wish list a mile long
            What rod for best penetration on AC?
            6011 is the best rod for penetration on AC. It also is more forgiving for dirty metal and good for filling in gaps with the fast freezing puddle, utilizing the whip technique. As was mentioned the cleaner the metal is always better for any welding process.
            Skip
              Clean surface..
              If asking if cleaning the metal will help penetration, absolutely! It's a proven fact and it only makes sense as you increase the conductivity with a clean surface which in-turn delivers more current to the work surface. Stick has always been a good choice in wind and on surfaces that are less than clean due to the mass (size) of the electrode (wider area of contact). But as mentioned above all electrodes differ from one another and as mentioned above, the 6011 delivers the most penetration in all weldable conditions.
              My 2 pennies worth, good luck..
              TacMig
              We depend On:
              Burco/Koco | Onan | BobCat
              We belong to or support:
              American Welding Society
              The Welding Institute
              Anderson & Co. LLC
              Metal Cr
              afters
                Definitely.
                And, I'll take issue with some of the advice you've been given.
                IMO, 6010/11 runs best on DCEP. Both of those rods are difficult on AC. 6013 runs really sweet on DCEP. While it is a high titania rod (soft arc, shallow penetration) it is certainly adequate for any trailer frame I've ever seen with good joint prep.
                If all you have is AC, I'd recommend EXX14. It gets medium penetration, runs nicely on AC, and is easy to clean up.
                Also, there are no stupid questions!
                Hank
                ...from the Gadget Garage
                Millermatic 210 w/3035, BWE
                Handler 210 w/DP3035
                TA185TSW
                Victor O/A "J" series, SuperRange
                  Correctomundo
                  I was hanging on the clean thing, but your advice on AC using EXX14 was right on. It's been so long since I've used AC I forgot. Thanks for the refresher.
                  TacMig
                  Originally posted by hankj View Post
                  Definitely.
                  Hank
                  We depend On:
                  Anderson & Co. LLC
                  Metal Cr
                  afters
                    ACXX14 would be a good choice. 6013 has never been one of my favorites but I know alot of guys that swear by the stuff. 6011 is a good all-round rod for most applications, and will run well on AC or DC. However, if you have a machine with DC capabilities, pick up some Lincoln 5p+ 6010, won't run for **** on AC but on the DC side it can't be beat. At work on the old Forney, I use 1/8" 6011 (110-135 amps AC) on most applications, or 3/32" 7014 (85-100 amps AC) on the smaller stuff. When I have access to my Thunderbolt, I use the 5p+, 1/8" 6010 (110-135 amps DCEP), and cap that with 1/8" 7018 low-hydrogen (135-150 amps DCEP). Good surface prep is always a good idea. Hope this helps
                    At Home
                    Miller Thunderbolt XL AC/DC
                    Performance Tools 6" Bench Grinder
                    Craftsman Hand Tools
                    Craftsman Cordless Drills
                    DeWalt Angle Grinder
                    1976 AMC Jeep CJ7
                    1980 Ford F150 Custom
                    1994 Chevrolet Silverado C1500
                    At Work
                    Miller Bobcat 250
                    2 Miller MM251s
                    2 Miller MM252s
                    Miller Dialarc 250 AC/DC
                    Lincoln Idealarc 250 AC/DC
                    Snap-On Flux Core Welding Machine
                    Hypertherm Plasma Cutter
                    Victor Torches
                    2006 Chevrolet Silverado 2500HD 4x4
                    Proud American Ham KE5TJA
                      Yes. If you cleaned the metal it will weld better. Contray to popular salesmen belief, there is no rod to weld through grease, dirt, paint, ect and make a proper weld. Acceptable for your purpose, maybe, but not proper.
