Syncro 200 tig problem I think
  • Syncro 200 tig problem I think
    I havent used my tig for a while and thought I would get some practice in on aluminum. I ran a few short beads with no problem...hf start ok etc. On the fourth the hf start would not arc so I let my foot off the pedal and the post
    purge was on for about 10 seconds more. I'm set on 175 amps/AC/clean metal with good ground close to weld area. I tried again,same thing, no hf start. Third try it just blew a nice blackish hole in the material all the way through at start. alum is .060. This rarely happens but it does at times. Next bead went fine. No, the tungsten never touched the weld.
    Any Ideas........The material is 1.5 x 3/8 extruded box channel.
    Nick
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    did the Tung. frost ??
    try striking it like a match to clear the frost then HF it, might help.
    sigpic
      Doesn't that just contaminate the tungsten.......this has HF start
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      2-O/A outfits
      Jet Lathe and Mill
      Propane Forge
        you would think so, but its just what i have heard the other guys do with frosted problems. if its cold i don't think the Tung. will pick up any aluminum from a small scratch to clear the frost. may not work, but cant hurt anything. if it doesn't work you still needed to resharpen the tungsten any way right.
        sigpic
          My 250 does that once in awhile. Pedal off, touch tip to work. Begin again normally. I had been doing this for a long time, but I didn't know why it worked.
          FWIW: I've been reading past posts, somewhere in the last 96 pages, someone mentioned that a capacitor discharges when 'tip touching'. Allowing the HF to start right on your next try.
          RETIRED desk jockey.
          Miller Syncrowave 250.
          sigpic
            yup Craig is right, my 180 would do that every so often. i just tuched Tung to the work with the power off. somtimes a small arc would jump to the work somtimes not.
            Paul
              The Lincoln Prescision Tig at school would do this sometimes. If you touched the tungsten to the metal, occasionally you would see a small spark, it would work after. I was working with low carbon steel, if that makes any difference.
              Makita 5" grinder
              Makita 14" abrasive saw
              IR SS5L compressor
              and a wish list a mile long
                I had this problem with my sync 200.
                I found that the tugnsten was carboned back up inside the torch where it makes contact.dirty ,bad connection .
                I cleaned it ,problem went away.
                Rich
                sigpic
                Love the power of Blue
                Millermatic 200
                Sync 200
                Lots of Tools!
                  Thanks for all the responses.
                  Fun...at first I thought you meant scratch with pedal depressed. Then I reread your post.
                  How often do you guys resharpen your tungsten? Seems like I need a six shooter torch. I'm using the red band 3/32". I hear they will handle most procedures. Thoughts.
                  Nick
                  Nick
                  Miller 252 Mig
                  Miller Cricket XL
                  Millermatic 150 Mig
                  2-O/A outfits
                  Jet Lathe and Mill
                  Propane Forge
                    Nick
                    i also use red 3/32. i use it up to 200 amps then go to green but it allows you to lay a 1/8'' bead on aluminum........
                    miller 330 abp
                    everlast 225lx
                    airco 250a tig
                    hobart handler 125 mig
                    o/a torches
                      I think there's a proper chemistry answer to 'how often'. But it doesn't pertain to me. I dip the tung in the puddle or dip the filler in the tung so often I never get to use the chemistry.
                      LMAO!! This would be handier than a wireless remote.
                      Nick
                      That's what I use cause that's what I have a supply of. On both alum and MS (small garage-guy stuff). I suppose I'll try the lantanated ones next time I buy. OBTW: x-former.
                      sigpic
