Project Specific Thread: Welding tables
  • Project Specific Thread: Welding tables
    Just had an idea to start a project specific thread. On this just post ideas and pictures for various welding tables that you have built or use regularly. This way we can start compiling information for easier research instead of looking for a dozen different threads. Not to sound rude, but if your table is simply a slab of plate with four legs, you might abstain from posting. On the other hand, if you have an idea that you think the rest of us would benefit from, by all means post away, especially with pictures. SSS
    Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
    Cat 242B Skid Steer, Challenger (Cat/Agco) MT275
    1 Thessalonians 4:11-12
    Welding Tables
    Great idea! I was going to use the Miller project table on this website but I wanted to put some type of threaded rod or screw-type thing on the legs so that the table could always be leveled and could be adjusted to the height of the table saw, BS, drill press, etc.
      I've got some nice slab tables. Very handy for many things. But more of my tables are a skeleton design, of various sizes. This allows clamping at many different locations within the framework of many fabrications. Some of these tables are very lightweight, others are made from 5/16x3x4" angle. When I get a job that a current table won't do very well, I build another table. Eventually, it's rare that I don't have a table that does the next job.
      I'll have to find some pictures later.
        Originally posted by atpav8or View Post
        ...I wanted to put some type of threaded rod or screw-type thing on the legs so that the table could always be leveled and could be adjusted to the height of the table saw, BS, drill press, etc.
        Great idea, especially when you drag it to different spots in a shop and no floor is perfect.
        For just leveling purposes in fact, you only need the adjustment on one leg.
          How about a slab, four legs and a dead chicken? Now that's funny....I don't care who you are
          Nick
          Miller 252 Mig
          Miller Cricket XL
          Millermatic 150 Mig
          Miller Syncrowave 200 Tig
          2-O/A outfits
          Jet Lathe and Mill
          Jet 7x12 horz/vert band saw
          DeWalt Multi Cutter metal saw
          Century 50 Amp Plasma Cutter
          Propane Forge
          60" X 60" router/plasma table
            I doubt you can level it with one adjuster unless it's a three legged table, and that would only be on one axis. What about three adjusters and one leg.....maybe that needs more thought
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            2-O/A outfits
            Jet Lathe and Mill
            Propane Forge
              Sorry, I said "level" but I was thinking something else. Good catch. One adjustment will allow you to prevent the table from rocking on any surface. But yes, you would need more adjustments to truly "level" it. Thanks.
              I usually just shoot for level in one axis (on both sides). That guarantees that it doesn't have a bind, which is all that's important for most fabrication.
              So, probably just putting the adjustment on each leg is best for meeting any need.
                I know what you meant Mac.........I was just being awnry
                Nick
                Miller 252 Mig
                Miller Cricket XL
                Millermatic 150 Mig
                2-O/A outfits
                Jet Lathe and Mill
                Propane Forge
                  terrys welding table
                  This is our welding table I have made two of these one for work and one for our shop It is 1/4 x 4x8 and 3 inch channel legs with 2 inch angle frame heavy expanded metal on bottom.It has 4 recepticals at each end works real well.
                  miller bobcat 250
                  wc 115a
                  spoolmatic 30a
                  centery 250 mic
                  2 lincoln 225 stick
                  a 1954 hobart portable welder w/ willies jeep engine
                    Pretty standard 4'x8'x1/2" top, 4" channel, 3x3x1/4" legs, and a pipe rack on the back consuming otherwise useless space.
                    AIM: Zachary188
                      Can't build this one unless you own a foundry. They were going to take it to the scrap yard. Got it for free. TJ
                      Miller Syncrowave 250
                      Miller CP 200 w/S21-E & Spoolmatic 3
                      Miller Bobcat 225
                      Hobart R-300
                      "There are two kind of people in this world. Those who can weld and those who can't." Jesse James
                        My Welding Table Minus Dead Chicken
                        Here are some pictures of my main welding work table. It is 44 " x 97" x 5/8" thick, sitting on 3 x 3 x 3/8 angle frame being supported on 6-4 x 4 x 3/8 square tubing legs with a bottom shelf as you can see. It took a bobcat to bring this into my shop. My friend and I built this a few years ago. You could park your car on this table and it wouldn't budge. I will describe the pictures in order of their appearance.
                        The 1st picture shows 1 x 2 C channel bolted to table for railing assembly
                        2nd picture shows another view of same
                        3rd picture - notice each leg has a receiver tube for a MIG torch
                        4th picture - notice CNC Router machine in background that made the last picture I show here (for my neighbor who just lost a loved pet)
                        5th picture - notice hardy hole (spelling might be wrong) for accessories such as shrinker/stretcher shown.
                        6th picture- notice to the left of the shrinker/stretcher, the pair of 1 " round
                        welding to underneath of table surface to bend/straighten metal pickets etc.
                        7th picture- picture of Memorial Plaque for neighbor who lost pet made with CNC Machine in 4th picture.
                        Nick
                        Miller 252 Mig
                        Miller Cricket XL
                        Millermatic 150 Mig
                        2-O/A outfits
                        Jet Lathe and Mill
                        Propane Forge
                          More Pictures of Welding Table Minus Chicken
                          The previous post would only allow 5 pictures so here is the last two.
                          The first picture here is bender fork for straightening metal, etc
                          The next one is- Memorial plaque for neighbor's pet.
                          Nick
                          Miller 252 Mig
                          Miller Cricket XL
                          Millermatic 150 Mig
                          2-O/A outfits
                          Jet Lathe and Mill
                          Propane Forge
                            One thing I seen that I thought was cool was a guy at work welded a piece of 2" angle to the side of the table. On the long side of the rectangle work table the angle was welded flush with the top and the "V" of the angle pointing down. It makes working with pipe very nice and easy! I want to add that to my current table.
                            Modern Metalworking L.L.C
                            Blissfiled, MI
                            517-605-9481
                            Miller Dynasty 350 Tig runner
                            Hobart 3-phase mig
                            Hypertherm 1000 plasma
                            Mill
                            Lathe
                            Box break
                            Shear
                              You'd be amazed how often you drop a square tube in there, too.
